20 Most Recent NetGear DGND3300 RANGEMAX DUAL BAND WIRELESS-N DSL GATEWAY Router Questions & Answers
2answers
Netgear router cannot set up wireless connection showing runtime error
you can do it without the disk although it is just a little on the advanced side here goes, nice and easy. 1) connect the cat5 (big telephone looking wire) from port 1,2,3 or 4 of your router to your computer 2) open a browser (IE, chrome, safari, whatever) 3) where you normally type web address type "192.168.1.1" 4) should ask for username and password (default for netgear is "admin" and "password") 5) click wireless and type the desired wireless name into SSID 6) click "save settings" or "apply settings" 7) for the password choose WPA WPA2 personal and enter your desired password 8) click apply or save again 9) test it!
7/26/2018 6:33:14 PM • NetGear DGND3300... • Answered on Jul 26, 2018
2answers
Can you help me configure my netgear router? I
you can try typing in your browser address bar www.routerlogin.net then press enter this should bring up your routers setting wirelessly but this will only happen if your laptop detects your routers wireless network.
if you can connect your laptop to your router using ethernet cable you can go to the command prompt then type in IPCONFIG then enter this should pull up your ipaddress and the default gateway is your routers Graphical User Interface where you can go and change the settings, your Netgear default gateway should be 192.168.1.1 this is the default gateway that should show in command prompt for netgear routers.
If you are going to use wireless make sure in the router the wireless capability of your router is enabled ^_^
your settings depend on what your Internet service provider requires you for settings
10/1/2015 8:35:05 PM • NetGear DGND3300... • Answered on Oct 01, 2015
2answers
Password negear gateway cc3000d
You will need to press and hold the reset button on the back of the router for about 10 seconds. This will reset the configuration to it's defaults. Then you will need to set the router back up again.
10/1/2015 8:34:26 PM • NetGear DGND3300... • Answered on Oct 01, 2015
2answers
Hooking up a printer to a Netgear CG3000D Home Gateway
If you provide the printer make and model it would be helpful. Open the printer Wi-Fi settings select your SSID , enter password, connect.
10/1/2015 8:32:46 PM • NetGear DGND3300... • Answered on Oct 01, 2015
2answers
Need to reset Netgear DGND3300 router everyday
You could try a factory reset on the router, hold the reset button on the back for 15 seconds. Reconfigure and test. If that doesn't work, go to the manufacturers site and download and install any newer fireware available. If that still doesn't work or none are available you would be best off simply replacing it. You can get some decent w-routers for $40.
10/1/2015 8:25:25 PM • NetGear DGND3300... • Answered on Oct 01, 2015
Zyxel tm6841g default
This page gives you how to set up this router, which better called the P-600 series. Zyxel do not recognise it any more. Default: Username: admin Password: 1234 Default gateway: 192.168.1.1 http://pctechnotes.com/how-to-configure-zyxel-p-600-series-with-pldt-mydsl/
3/9/2015 4:19:04 PM • NetGear DGND3300... • Answered on Mar 09, 2015
My iphone 4 has become slow to connect to my Netgear DGNDv2 modem router. The connection used to be really quick but now I have to repeatedly tap the refresh button on the iphone to get it t connect.
Things That Affect Wireless Router Signals 1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel. 2. Analogue video senders used to send audio and video to other TVs in the home. 3. Microwave ovens emit interference in the 2.4GHz band. 4. Wireless speakers and console controllers can cause interference with the wireless router. 5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem. 6. Power cables located near the wireless router can cause dropouts and speed reduction. 7. Fish tanks will cause massive Wi-Fi shadow on the other side of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflect wireless signal away your computer. 9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
3/10/2013 8:53:07 PM • NetGear DGND3300... • Answered on Mar 10, 2013
HOW DO I CONFIGURE MY ROUTER TO ACCEPT T
Connect with network cable and make sure both are set to DHCP for auto config.Or manually set an IP's on both units. You need enter Subnet Mask and Gateway.
11/11/2012 7:16:59 AM • NetGear DGND3300... • Answered on Nov 11, 2012
4answers
Silly question - should the blue flashing light be
yes
8/31/2011 6:07:19 AM • NetGear DGND3300... • Answered on Aug 31, 2011
I have 2 problems:- The first is it seems that if
What you can at first check your router setting if there is a security set only for 1 computer and a pass key. If there is any, configure it to make the second laptop connect to the router.
4/12/2011 7:14:39 PM • NetGear DGND3300... • Answered on Apr 12, 2011
Not able to connect to internet
Hello.
If the Internet light is not on, but the other lights are on, the problem is typically with your provider. Contact Verizon or whoever is your provider.
Be certain you don't have the filter (white connector) connected to your router.
If still a problem, please provide more info such as whether the router was working and just stopped or if you have tried to connect to the Internet with more than one computer, etc.
Hope this helps.
1/16/2011 3:16:03 PM • NetGear DGND3300... • Answered on Jan 16, 2011
Cannt get full signals when
The same way you adjust your router: -
Chapter 1: Connecting the Wireless-G Broadband Router
Hardware Installation
1. Locate an optimum location for the Broadband Router. The best place for the Broadband Router is usually at the center of your wireless network, with line of sight to all of your mobile stations.
2. Fix the direction of the antenna. Try to place it in a position that will best cover your wireless network. Normally, the higher you place the antenna, the better the performance will be. The antenna's position
enhances the receiving sensitivity.
3. Connect a standard Ethernet network cable to the Broadband Router’s Internet port. Then, connect the other end of the Ethernet cable to your Cable or DSL Broadband modem.
4. Connect your network PCs or Ethernet devices to one of the Broadband Router’s numbered ports with a standard Ethernet network cable.
5. Connect the AC Power Adapter to the Broadband Router's Power Socket and the other end into an electrical outlet. Only use the power adapter supplied with the Broadband Router. Use of a different adapter may result in product damage.
Good luck.
2/15/2010 1:27:15 PM • NetGear DGND3300... • Answered on Feb 15, 2010
I recieved a new computer for christmas Emachine
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
1/7/2010 2:39:14 PM • NetGear DGND3300... • Answered on Jan 07, 2010
How To Connect With Mywifiext net Setup Page?
This sounds like an answer to someone's question? You need to click in the MY ANSWER box under the question. It doesn't work adding your ANSWER as a new QUESTION.
3/11/2023 6:13:39 PM • NetGear... • Answered on Mar 11, 2023
How to check netgear r7000 speeds ?
hi please find link for how to check speed https://kb.netgear.com/000038894/How-do-I-check-my-Internet-speed
11/25/2021 1:20:54 PM • NetGear... • Answered on Nov 25, 2021
How to connect PC to netgear WIFI extender
By connecting to your existing WiFi network and enhancing coverage, the NETGEAR range extender enhances your home WiFi network. The steps below will assist you in setting up your extender.We recommend using the Nighthawk app to set up your extension on our latest devices. See the following articles for more information:https://pnews.org/boost-your-speed-with-netgear-nighthawk-r7000/
11/18/2021 3:59:41 PM • NetGear... • Answered on Nov 18, 2021
Belkin f9k1106v1 range extender not connecting
QUICK TIP: When finding a location for your range extender, it is best to place it within the same room as the computer. You can also use https://192.168.206.1 to access the range extender's web-based setup page. Step 1: Place the range extender in an area where the Wi-Fi signal of your router is strong, but near where you want to establish your extended network. Step 2: Plug in the power supply of the range extender and make sure that it is powered ON. Shortly, its light will begin to flash blue and orange. Step 3: Place your computer near the range extender. Also, make sure your computer is not wired to any other network devices. Step 4: Connect your computer to the range extender by opening the list of Wi-Fi networks and selecting Belkin.setup. Confirm that the list shows it's connected. Step 5: Open a web browser, enter https://belkin.range into the Address bar, and follow the on-screen instructions. Don't forget to type "http". Once the setup for your range extender is complete, you may connect the computer to its Wi-Fi.
9/12/2021 1:30:03 PM • NetGear... • Answered on Sep 12, 2021
How can i connect Netgear AC1750 Wifi Mesh Extender manually ?
By Following these steps you can easily setup your Netgear wifi range AC1750 extender
  1. Turn On Your Extender by plugging it into the power outlet, Wait till the extender is turned on and the power led light to stop blinking Once the device is fully booted up,
  2. Now open your web browser, enter mywifiext.net in your web browser if you are Are going to setup your range extender using the window device.
  3. Click on the New Extender Setup , Now Create a new account in case you do not have an account Already.
  4. Accept the term and conditions, Click Continue
  5. Now you will be asked whether you want to Configure your Netgear extender as a wifi extender or as an access point
  6. Click as a Wifi Range extender
  7. Now choose the network you wish to extend and click on the Next button
  8. Enter the password of your current wifi and click next
  9. Be Patience and wait for few seconds.
You had successfully setup your AC1750 Netgear range extender, in case if you are facing an issue with login into your Netgear extender read our extender login guide .
5/6/2021 2:30:13 PM • NetGear... • Answered on May 06, 2021
NetGear DGND3300 RANGEMAX DUAL BAND WIRELESS-N DSL GATEWAY Router Logo
24 questions posted
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • NetGear Computers & Internet
Most Popular Question
iphone 4 become slow connect netgear
  • Computers & Internet
