20 Most Recent
Encore ENHWI-N2 802.11n Wireless Router (Atheros chipset) Questions & Answers
My router crashes when I try to play online games,
that sounds like a fault. maybe you should check for any firmware updates but that process may effectively erase your router settings so it would need reconnecting to your iSP afterwards...probably. good luck youll need it.
When MAC filtering on Encore
The MAC address is a 12 digit number. This number is organized into 6 pairs of Hex numbers with no spaces between each pair of Hex numbers.
A Hex number is 0 to 9 and A to F giving a range 16 possible numbers.
An example of a MAC address number is - 0000AFB9C3F9
When you configure the wireless router with MAC address filtering, the router will only allow the computers with the MAC address listed in the router to connect to this wireless router.
Forgot the router password
Press a restart button at the back of your router, hold it like that for 20 seconds.That should take back all settings to default.Now you can go to 192.168.1.1 and type default username and password( try admin/admin, or admin/blank, something like that, you can at the bottom of your router box)And when you enter, there you can set up your new password and choose another router settings..Good luck, I hope this will help you
Can't identify wpa passphrase to hook up my new
WPA paraphrase should be a 10 digit number printed on the bottom of the router if you didn't change it. If someone set it up for you and changed it, try your 10 digit phone number. If this doesn't work, let me know and we'll troubleshoot it.
Create wireless security
1.Enter IP address http://192.168.1.1 (the factory-default IP address setting) to the URL web address location.
2. When the following dialog box appears, enter the user name and password to login to the main configuration window, the default username and password is “admin”.
3.Setup wizard is provided as part of the web configuration utility. User can simply follow the step-by-step process to get the wireless Router configuration ready to run in 6 easy steps by clicking on` the “Wizard” button on the function menu. The following screen will appear. Please click “Next” to continue.
4.Set Wireless LAN connection
Click “Enable” to enable Wireless LAN. If user enables the Wireless LAN, type the SSID in the text box and select a communications channel. The SSID and channel must be the same as wireless devices attempting to connect to the WLAN Router.
(When in FCC domain, you could chose ch1~ch11; in ETSI domain, you could chose ch1~ch13)
4. Click on Security.
5.Security
This function enables user to set authentication type for secure wireless communications. Open System allows public access to the router via wireless communications. Shared Key requires the user to set a WEP key to exchange data with other wireless clients that have the same WEP key. This router also supports WPA, WPA2 and WPA-PSK, WPA2-PSK.
6.Set the Security key and save the settings.
7. The Wireless is secured now.
You can find more information in the User Guide.
Here is the link: refer page #26,27,33 to get all the info.
http://www.encore-usa.com/us/sites/default/files/product_documents/ENHWI-N2_Manual_Cam.pdf
Renew password
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.1.1
or
http://192.168.0.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then WPA Security then not down code .It is your password to connect wi fi..
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
How can i put a password on my Encore ENHWI-N2
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
I have windows 10 and I am using Printshop deluxe 6.0. I worked fine since it was purchased Oct 2022, all of a sudden it won't print my projects and I can no longer save them as JPRG
If PrintShop Deluxe 6.0 is no longer printing your projects and you are unable to save them as JPRG after uninstalling and reinstalling the software, there may be a few other things you can try to fix the problem:
- Check the printer settings: Make sure the printer is properly set up and connected to your device. Check the printer settings to ensure that it is set to the correct printer and that the printer is not experiencing any errors or issues.
- Check for updates: Check for updates for the software and the printer driver. Installing any available updates may fix the issue.
- Check for compatibility issues: Make sure that PrintShop Deluxe 6.0 is compatible with your version of Windows 10. If the software is not compatible, it may cause issues with printing and saving projects.
- Repair or reinstall the software: Try repairing or reinstalling the software to see if it fixes the issue. Make sure to follow the instructions provided by the manufacturer or technical support team to properly uninstall and reinstall the software.
If these steps do not help, you may need to contact Encore or a technical support team for further assistance. It is also a good idea to check the documentation or manual that came with the software for any troubleshooting tips or recommendations.
I have the 112 twelve
Please clean the discs in + manner. Meaning, take a soft cloth and rub it un-down and sideways and not in circular manner we usually do. Also clean the read/write head of the CD drive. It is the shiny blue dot. try running the discs in your friends computer to make sure they are fine and not damaged.
