20 Most Recent D-Link WBR-1310/RE 54Mbps 802.11g Wireless LAN/Firewall 4-Port Router Questions & Answers
if you know the current password to the router please login to it by going to
http://192.168.0.1
if you dont the default login/password is admin/admin
once you login go to the tools link
below you can change the password.
if you want to change the wireless network password go to
setup>wireless settings
and change the security password there.
D-Link... | Answered on Dec 19, 2013
You can unplug it & it
should hold it's settings
D-Link... | Answered on Sep 11, 2013
Try resetting your router and then configure it again.
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ON until the LEDs flash at the time the release the RESET button. (firmware version was 3.00, and upgraded to 3.05) Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. (SSID, WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access). Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
D-Link... | Answered on Feb 19, 2013
This is not possible with this router to my belief. What you want to do is buy an open sourced router that way you can get into it and set the password yourself :)
D-Link... | Answered on Jun 20, 2011
login to your router via your browser to 192.168.0.1
login/pass admin/admin
click on setup, wireless settings
click on the dropdown list next to wireless channel to change the channel.
D-Link... | Answered on May 29, 2011
I know it is a pain but to determine if the D-Link is faulty, try resetting the D-Link back to the default settings and configure it again -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
D-Link... | Answered on May 28, 2011
There is a reset button on your device. Look for a small hole.
First turn off your device. Press and hold down this button using a paper clip while turning on the unit.
This will reset the settings back to its default.
Let me know the outcome.
D-Link... | Answered on Feb 03, 2011
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
D-Link... | Answered on Jan 31, 2011
Hi!
How would you like to connect it to your Home PC wireless or wired?
You have two ways to connect it.
Keep me posted. Thanks for using Fixya Online Support.
D-Link... | Answered on Jan 12, 2011
Only way is to reset router to default settings by pushing reset button on router then you will need to reconfigure router again by following those steps:
  1. Connect your computer with router through utp cable
  2. Open your browser and type http://192.168.0.1
  3. Default password and user name is admin
D-Link... | Answered on Dec 29, 2010
You can reset the router by following below steps, this will automatically bring you to set password:
1. Find the reset hole which is placed in back of the router.
2. Place a pin or pen tip on the reset hole and press the pin (Must do this while the router is in ON state and as well is in OFF state)
3. Then connect your router through ethernet port to computer.
4. Configure new password to the router.
Most probably the router IP address is 192.168.1.1
Username: admin
password: password
Please try this steps and provide your valuable feedback.
Thanks,
Satheesh
Try admin with no password.
http://www.default-password.info/d-link/
If that doesn't work you will have to reset the router to factory defaults by holding the reset with a paper clip or something for 10-12 seconds (Beware, this will default the router, you will have to set it back up from scratch)
D-Link... | Answered on Dec 22, 2010
IN order for you to enable wireless security on your network you need to access the router setup page where you can setup all the settings for it including the wireless security
So to do that access the router setup page and once there look for a wireless portion on the setup page and from there you will be able to see the place to enable WEP or WPA I suggest you use WPA which is a much stronger level of security that you can use.
D-Link... | Answered on Dec 04, 2010
Try these basic troubleshooting steps:
  • Change the channel on your access point or wireless router.
  • Change the location of your wireless products. Subtle changes (2-3 feet) can make a big difference. Do not put the access point or wireless router in a cabinet or enclosure.
  • 2.4GHz phones, X-10, and bluetooth devices will interfere with your wireless network. Change the location of the base for your phone, or downgrade to 900Mhz phones, or upgrade to 5.8GHz phones.
  • The wireless signal will degrade (or die completely) when going through brick (fireplace), metal (file cabinet), steel, lead, mirrors, water (fish tank), large appliances, glass, etc.
If your wireless connection is only dropping during large file transfers or when a large number of wireless clients are connecting, change the preamble on all wireless devices to short.
If you need more help come back.Post / thumbs / testimonial are welcome!
D-Link... | Answered on Nov 19, 2010
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is usually 192.168.1.1 or 192.168.0.1 and lookup for the options to do the following: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password (unless you've configured otherwise, the default username is admin and the password password.)
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Settings" 2.Under "Security Options", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Apply
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
Feel free to contact me for further assistance
CreativeTECH
D-Link... | Answered on Nov 16, 2010
Ve a D-Link - TechSupport FAQ y has click en basic y continua el procedimiento.Si no puedes con ello escribeme o postea luego.
D-Link... | Answered on Nov 08, 2010
D-Link WBR-1310/RE 54Mbps 802.11g Wireless LAN/Firewall 4-Port Router Logo
33 questions posted
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Computers & Internet
Most Popular Question
change
  • Computers & Internet
