20 Most Recent
SonicWALL TZ 210 WLS-N TOTAL-SECURE NTWK SEC APPL 1YR (01-SSC-8773) Firewall Questions & Answers
Problem in Sonic FireWall
Check with your ISP for whether they have blocked Port POP3 Port 25 or not. also allow (Open) this port in Sonic Firewall also.
POP3 Default Port 25 but many provider use different Ports so also make sure that you configured correct port.
Strange noise
Sounds (pun intended) like one of the cooling-fans has worn-out bearings, and is "screeching", just before it totally freezes-up, and dies, and causes your SonicWall to overheat.
7/29/2014 3:53:48 AM •
SonicWALL...
Answered
on Jul 29, 2014
UPNP over sonicwall
For "security" reasons, you should not all UPNP traffic from "outside" of your network to enter your "internal" network. Block it.
7/29/2014 2:58:47 AM •
SonicWALL...
Answered
on Jul 29, 2014
Remove pc performer from my computer
Hi you can remove the PC Perfomer using the software Ccleaner.
CCleaner 4 09 4471
select tools and uninstall the PC Performer, if it doesn't uninstall then select delete entry. Also Ccleaner makes your computer faster by removing temporary files/cleaning registry. Hope this helps.
5/30/2014 6:08:17 AM •
SonicWALL...
Answered
on May 30, 2014
Hack the sonic wall
Hacking is a broad term and there are many attack vectors which you can use. If you do not truly understand that then you will not be cracking a firewall. You need a method of attack, recon it and search the vulnerabilities.
4/28/2014 7:07:17 PM •
SonicWALL...
Answered
on Apr 28, 2014
