20 Most Recent Zonet ZEW2545 IEEE 802.11b/g IEEE 802.11n Draft 2.0 USB 2.0 Wireless Adapter Up to 130Mbps Data Rat... Pre-802.11n Questions & Answers
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop/desktop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
Zonet ZEW2545... | Answered on Apr 10, 2011
Back when P4 systems were common, the hard drive interfaces were quite marginal for video processing and techniques to force the capture to faster devices (like a RAM drive, or now
SSD drive, or SCSI interface to high end striped drives) were used to smooth the video capture. I have had good luck with SATA3 interface SSD's for capturing video, but continue to use a drive other than the one I boot from so windows doesn't mess up the frame rate.
Zonet Computers... | Answered on May 18, 2017
First: GENERAL ROUTERS RESETING
Second:
http://www.fixya.com/support/r7900574-general_router_setup
Zonet Computers... | Answered on May 12, 2015
POORLY supported routers made in China. STRONGLY recommend disposing of this device and obtaining one from a better vendor that supports it's products i.e.: Cisco, 3Com, etc...
Zonet Computers... | Answered on Jul 23, 2014
Contact seller or company that makes it. May be a download item on maker's site.
You could try Getright software, but most likely you are having connection problems (low bandwidth or high error rates). Problem is not likely in the router unless your wireless signal strength is very low.
Zonet Computers... | Answered on Jun 08, 2014
It's not a big deal. The base address may vary for various routers, and you can adjust it according to your current network configuration (I mean other TCP strings)
Zonet Computers... | Answered on Apr 24, 2014
In order to fully answer your question, a number of needful things must be inspected, reinstalled, confirmed, & tested:
  1. Reset. Try the reset button. You could use a paper clip to reach the reset button through the pin hole in the lower front left of the Zonet KVM unit.
  2. Inspect connectors. Each data/input/power connector/port requires all of its pins to be present & straight for full functionality.
    1. Inspect the entire length of each cable & cord to ensure that each has no damaged area.
    2. Seat each connector in the appropriate port of a computer that will be accessed via the KVM unit.
  3. Electricity. Inspect all affected devices & confirm that each has sufficient, uninterrupted electricity.
    1. It is possible for a Zonet KVM unit to display channel lights without direct power to the unit, but you should confirm that the unit is getting sufficient, uninterrupted electricity-directly through its own power cord. Unplug the KVM power cord & every connector & reseat each one (this performs a power reset on the KVM unit)-making sure that each connector is in the correct location (not just where it originally was). Thus, make sure that the keyboard, video display (monitor), & mouse are on the output side.
    2. Press the power button on your monitor. If it does not turn off the monitor's power status light (Off/On/Standby), then remove the power cord from the monitor & reseat it-to reset the monitor's hardware. If it does not turn on the monitor's power status light, then the monitor is either not getting enough electricity or it has a malfunction which requires troubleshooting & fixing (possibly through a fixya.com thread for that monitor model).
    3. Unlike USB devices, PS/2 devices usually require device connection prior to turning on that device. With that said, connect the keyboard & mouse KVM channel cable connectors to the computers & then turn on those computers that you intend to display through the KVM-connected monitor & then turn on these computers.
    4. Any computer that does not turn on has an issue that requires resolving (just like a monitor that would not turn on).
    5. Sometimes a keyboard/mouse interface issue can be resolved by replacing that interface device.
  4. The KVM Unit. When all else properly connects & performs, what does not properly connect & perform has the issue &, hopefully, that can be repaired without having to replace it.
Zonet Computers... | Answered on Jan 19, 2014
Do a factory reset - usually a 'secret button' hidden on the back - default router passwords can often be found on the net.
Zonet ZEW2545 IEEE 802.11b/g IEEE 802.11n Draft 2.0 USB 2.0 Wireless Adapter Up to 130Mbps Data Rat... Pre-802.11n Logo
Popular Tags
6 questions posted
Top Zonet Computers & Internet Experts
Barbat Nae
Barbat Nae
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ZEW Zonet
  • ZEW Zonet
Most Popular Question
internet connection but will not
  • Computers & Internet
