20 Most Recent
Belkin N150 (F6D4050) 802.11g/b Wireless Adapter Questions & Answers
How do i restore default settings on this router
Should be a reset button on the rear of the router. You will need a thin pin or a ball point pen to push it in. Hold it in for about five secounds when router is powered up and it will reset itself to the settings it had when you got it out of the box.
I have had to reload
If you have a working Windows wireless machine, you can extract the key from the Windows machine and use it on your other devices.
Download this:
http://download.cnet.com/WirelessKeyView/3000-2092_4-10614187.html
and then run it.
You can learn the WEP or WPA key in use which you can then use on other devices.
If there are no other working wireless devices, you will need to log on to your access point and reset the password there. The instructions for that depend on your access point.
Cant access the internet with
Please read over this troubleshooting guide by Belkin.... Just because you did not set up an administrator password should have no effect on the Internet connectivity issues.... They ship from the factory by default without a password set - FWIW, I run my router without anything changed from default settings and I have no problems with connecting to the Internet....
http://en-us-support.belkin.com/app/answers/detail/a_id/80
If after you complete the troubleshooting steps outlined above and you still have a problem, please post back and let me know and I will continue with troubleshooting/assisting you.
Also - here is a page or two of default passwords... if it is requiring you to enter one, find yours on the list and try that. See if that will let you get access so you can change it to something else....
http://www.routerpasswords.com/ http://www.phenoelit-us.org/dpl/dpl.html
Thanks
I have to router plugged up right but its still
Use an Ethernet cable to connect the network-port on your computer to one of the 'LAN' ports on the router.
Then, access the web-server "inside" the router, and login to the router, and run the "Wireless Networking Setup Wizard", to configure the wireless adapter:
* set an SSID -- your "network-name"
* set an encryption-level -- use 'WPA' or 'WPA2'
* set a password
Then, use the SSID/password on your wireless device(s).
What is the pbc button
installed on friends computer with bt router and connection request to press pbc button
Unable to configure my wireless belkin N150
As i understand you have a router provided by your ISP: MTNL, you need to configure the Belkin router in Dynamic mode and not in PPPoE. Then restart the devices by unplugging the power from MTNL router and Belkin. Wait for 20 secs, then power up MTNL router 1st, wait for all lights to get steady and finally power up the Belkin wireless router. Then you will find the modem and internet light lit up properly.
For any further clarifications, revert!
Thanks and regards,
Arvind
Setup assistant won't run!
This dongle ahould auto detect and auto install. Shut down your PC, plug in the dongle and re-boot. If the dongle is ok, windows will detect it and install the drivers. If you have an early copy of XP, you may have to download and install USB drivers.
I have a belkin n150 to use with my ps3. I get
It's the router. The download rate sucks. I'm sure if you've ever tried watching videos on You-Tube via your WIFI connection, you probably get aggrevated with it because the video will play for like 30-45 secs and then lock up. The easiest way to solve these problems is to direct connect whenever possible.
Hope this helped you. Good Luck!
I keep losing the connection to my Linksys N
1.Primarily, if you use a N standard wireless router, you must go in for the same N standard adapter, to get full efficiency. You didn't mention the model no.
2.If you have any other wireless computer in your house, check with that if it also has the same issues. Try checking with new and old wireless devices.
3.If finally, you conclude that its only this Belkin adapter that is responsible for intermittent connection, then:
3a. Uninstall the Belkin adapter's utility and drivers from control panel(Add/Remove programs)
3b.Go to http://en-us-belkin.com/support and download the latest drivers for your model.
3c. Unplug the adapter and run the downloaded setup file. (Setup will walk you through from here)
But i could have helped you better if you had mentioned the model or part number along with the version of it.
Anyway, this would certainly work.
How to instal a belkin n150 with a series 660
Are you trying to install the router.
You can do it manually without the CD.
MAke sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
How do I add two more computers on a wireless
Easily. The router supports up to 250(!!!) simultaneous connections.
Just select the SSID you configured into your router,
and enter the password/passphrase that your configured into your router.
