20 Most Recent Sunpak 622 Super Pro TTL Flash Questions & Answers
For something of that age, repair may not be an option due to lack of spares. May be better to replace it. Be wary of using it on digital anyway, as the high trigger voltage may fry the camera's internal electronics.
Sunpak 622 Super... • Answered on Jun 16, 2017
The flash heads just plug into the unit. You slide off the normal head and slide in a different one. The pins also code the GN changes so the display on the back are consistent with the head used.
Sunpak 622 Super... • Answered on Feb 08, 2015
Tocad the Sunpak distributor in the US does still distribute one of the 622 series,so you might be able to get them repaired or get spare parts. Be aware the voltages and energies available in the flash capacitors are dangerous, so you have to have electronics knowledge/skills to work on them safely. There was an ebay seller who used to sell a scanned vewrsion of the service manual for the 622.
Sunpak TR-Pak II a NiCad flash battery pack with charger and Quantam battery both has cords for 622.
Personally I have taken out wire pair from removable battery pack of 622 and connected to 4 cells of Nicd type D battery pack made at home.(I placed that in my belt bag).
want more details ,feel free to email at [email protected]
You will need a "Hot shoe to PC connection adapter" to connect the PC sync cord to your camera Dot Line Nikon Hot Shoe to PC Connection Adapter
Sunpak 622 Super... • Answered on Feb 01, 2015
Sunpak 622 Auto Pro has 6.5 - 8.0 V trigger voltage. It should be OK for Nikon D6 Strobe TriggerVoltages
Sunpak 622 Super... • Answered on Aug 30, 2014
Alzo Digital, CT, USA
Sunpak 622 Super... • Answered on Dec 13, 2012
According to the list at http://www.botzilla.com/photo/strobeVolts.html , it's your call. The flash's trigger voltage is right on the border. Depending on the individual camera and flash, it may or may not be safe. Personally, I wouldn't risk it without something like the Wein Safe-Sync in between to buffer the current.
Sunpak 622 Super... • Answered on Mar 03, 2011
I have read reports of this working. To be safe you can cover everything but the center pin with electrical tape, or you can buy surge protectors for flashes to protect your camera.
I had the same problem - 10-11 secs on 240VAC. My solution was to get the Quantum Turbo SC for $450. It yields ~3sec recycle times. This pack for $150 should play nicely as well: http://www.adorama.com/JTMBPN.html?searchinfo=jtl+lancer+battery+pck It was out of stock at the time. The Sunpak TR2000 is $250, but it's Ni-Cd while the others are NiMH. There are other HV packs capable of powering the 622 w/ the fitting cable like Lumedyne IIRC. The AD-26 is still useful for non-action photography. The fastest time I saw posted is 1.5 secs, but it's a DIY job (search 'sunpak 622' on flickr). HTH,
Szilard
Sunpak 622 Super... • Answered on Mar 30, 2010
broncolor mobil i need service munual digram....
Sunpak 622 Super... • Answered on Oct 02, 2009
Sunpak does not offer dedicated (TTL) module to any digital cameras. The flash can only be used in auto mode, while the camera is set to full manual. The lens has to be stopped down according the working aperture on the flash, correct exposure will be maintained by the built-in sensor of the flash. Fire the flash using a simple hotshoe-to-PC cube if your camera doesn't sport a PC connector. Trigger voltage of the 622 is safe.
Sunpak 622 Super... • Answered on May 23, 2009
ToCAD America Inc.
53 Green Pond Road
Rockaway, New Jersey 07866, USA
Phone: 973-627-9600
Fax: 973-664-2438
Email: [email protected]
$ 111.00 to look and additional for parts and labor. Expensive.
Probably cheaper to buy one off eBay.
Sunpak 622 Super... • Answered on Mar 25, 2009
Hey there, I had one a couple of months back, but unfortunately I got rid of it since I no longer use it. But, you can certainly buy one online. Check out Amazon or Newegg. Good luck!
Sunpak Cameras • Answered on Sep 24, 2020
When it is not triggering either Tube is dead or Trigger circuit has a problem. You can get junk flash from Ebay.
Sunpak Cameras • Answered on Dec 06, 2017
Sunpak 622 Super Pro TTL Flash Logo
18 questions posted
Top Sunpak Cameras Experts
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
View Most Popular
Sunpak Cameras
  • Sunpak Cameras
Most Popular Question
like use
  • Cameras
