20 Most Recent Sunpak PZ 4000AF for Canon TTL Flash Questions & Answers
Regarding using the Sunpak 4000AF flash with my Canon EOS Digital Rebel, I can't get the flash to fire. There seems to be no combinations of settings that works to make the flash work. Could a weak battery in the Canon cause this? Does it require some other wire connector between the flash and the camera? I know this is old technology now, I have a pocket digital for most of my uses, but I'd like to try bounce flash again on my old Rebel digital, and so I've gotten out my old camera and the flash I had bought for it. I had bought the Sunpak flash years ago and I honestly don't remember if I got it to work back then or not. Thanks for any advice.
Sunpak PZ 4000AF... • Answered on Jan 21, 2014
Hi
you need to replace batteries
Sunpak PZ 4000AF... • Answered on Dec 11, 2010
The Sunpak PZ 4000 and 5000 were made for film cameras. I have one for my EOS film cameras. It works just fine. I know this series of flashes was not made for the digital cameras. It likely will not harm your camera if the flash is designed for your camera brand. But some functions will not work.
For example, do not use a flash for Minolta on a Nikon.
You risk damaging your cameras electronics or frying the flash.
Get their PZ 20, PZ 30, PZ40 or PZ 42X for your digital camera.
Sunpak PZ 4000AF... • Answered on Oct 20, 2009
Yes, you can use Ni-mAh re-chargeable batteries with Sunpak Pz 4000
Sunpak PZ 4000AF... • Answered on Jun 25, 2009
Canon digital uses E-TTL metering for best flash results, the older Sunpak unit isn't compatible with this, so it is not fully compatible. It may work in manual mode - but won't be as good as a more modern compatible digital flash like the Canon or Metz (eg 58AF1 Canon) versions.
Sunpak PZ 4000AF... • Answered on May 25, 2009
The Metz 40AF -4 is similar. You can download the manual from http://www.metz.de/en/photo-electronics/instruction-manuals/mecablitz.html (the manual is for Nikon, but I do not think it matters).
Good luck
Ole from Denmark
Sunpak PZ 4000AF... • Answered on May 23, 2009
The Alpha 100 only supports pre-flash TTL and ADI flash control which are not supported by the Sunpak. The flash should ignite, but automatic controlling of its brightness is not possible.
For more Information about the different Minolta/Sony Flash Metering modes cf. http://www.mhohner.de/sony-minolta/flashcomp_mm.php
Sunpak PZ 4000AF... • Answered on Jan 09, 2009
probably in MANUAL mode only.... my Nikon and Canon's work with the pz4000 (at a save trip voltage I may add) but in a manual mode as mentioned above.....
Sunpak PZ 4000AF... • Answered on Apr 19, 2008
Hey there, I had one a couple of months back, but unfortunately I got rid of it since I no longer use it. But, you can certainly buy one online. Check out Amazon or Newegg. Good luck!
Sunpak Cameras • Answered on Sep 24, 2020
When it is not triggering either Tube is dead or Trigger circuit has a problem. You can get junk flash from Ebay.
Sunpak Cameras • Answered on Dec 06, 2017
This should be covered in the manual - it is probably an error message of some description.
Sunpak Cameras • Answered on Oct 30, 2017
Sunpak PZ 4000AF for Canon TTL Flash Logo
21 questions posted
Top Sunpak Cameras Experts
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
View Most Popular
Sunpak Cameras
  • Sunpak Cameras
Most Popular Question
use sunpak 4000af canon rebel
  • Cameras
