20 Most Recent Sunpak DX-8R TTL Ring Light Flash Questions & Answers
I had a DX-12R for some time several years ago until it was stolen. I loved it. I recently purchased a used 8R and it is fine but I still like the 12R better. Especially the preview light feature. Ok. Make sure the batteries are all good, one bad apple does spoil the whole bunch. Check your cord connections and finally make sure the hot shoe connection is clean. That last one was usually the culprit when I had problems. Note that your hot shoe on your camera could also be going bad. I had a Ricoh that did that, I thought it was the flash. Good luck.
Sunpak DX-8R TTL... | Answered on Aug 19, 2011
Hello Don. THe DX 8R is a low output devise well below the 250 volts that Nikon mentions. Regarding the small label you site, the 50/60 Hz simply means you can use it in the states with 60 Hz and 110 volts or in Europe with 50 Hz and 220 volts with out any voltage converter. Finally the 45W indicates 45 watts.
All said, you should be fine with the DX 8R and all of your Nikon cameras. Regards, Joe
PS please rate my answer. Thank you and happy holidays
Sunpak DX-8R TTL... | Answered on Dec 21, 2009
You will need the proper module. Check with B&H photo for the module compatable with your Olympus camera body.
Sunpak DX-8R TTL... | Answered on Sep 19, 2009
According to what I read the sunpak dx-8r is, with the right module, compatable with digital SLRs. Check with B&H photo to get the right module.
Firstly, be sure to check flash voltage. Your 30D may accept max 6V so that your camera can be shot if the flash unit has higher voltage than 6V.
1. Use low ISO to keep low noise....around f/8 or more depends on your need and how much DOF you want.....Set the shutter speed around 1/125 to your max speed to stop any movement (your subject or camera itself shaking).
2. Above is set in Manual mode (iso100, f/8 1/125 or 1/250), then you just need to leave the flash to work in TTL mode.
3. It needs battery, the connection is for syncing to trigger and release a proper flash power (in TTL mode).
Hope this help!
Sunpak DX-8R TTL... | Answered on Sep 11, 2009
Google (sunpak)(4000)(manual) without parens OR request directly from Sunpak.
Sunpak Cameras | Answered on Jun 27, 2019
SADLY NO WE CAN NOT .CONTACT SUNPAK
Sunpak Cameras | Answered on Apr 17, 2019
When it is not triggering either Tube is dead or Trigger circuit has a problem. You can get junk flash from Ebay.
Sunpak Cameras | Answered on Dec 06, 2017
This should be covered in the manual - it is probably an error message of some description.
Sunpak Cameras | Answered on Oct 30, 2017
Have you tried other flashguns ? Does this unit work on test ?
Sunpak Cameras | Answered on Nov 15, 2016
I think you would need to send it for repair but be aware of the cost of repair as apposed to a new unit.
Sunpak Cameras | Answered on Mar 11, 2016
Yes you can. All you need is a small inexpensive slave unit.
Sunpak Cameras | Answered on Jan 29, 2016
Sunpak DX-8R TTL Ring Light Flash Logo
11 questions posted
Top Sunpak Cameras Experts
Paul Green
Andrew Taylor
Andrew Taylor
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
View Most Popular
Sunpak Cameras
  • Sunpak Cameras
Most Popular Question
sunpak dx 8r need module nikon
  • Cameras
