20 Most Recent Biostar G41-M7 Motherboard - Socket 775, Intel G41, MicroATX, DDR2, PCIe, USB 2.0 (802700502491) Questions & Answers
Usb port not working
IS USB ENABLED IN BIOS?.
8/10/2016 5:50:22 AM • Biostar G41-M7... • Answered on Aug 10, 2016
WARNING !! please clear CMOS if system no display after overclocking. how to fix it ?
remove the cmos battery for sometime (min 5 mins) and try again. If it still occurs then search for the CLR_CMOS jumper on the motherboard. switch positions and check. remove the jumper and check also. it should work. most cases removing the cmos battery works
2/23/2016 6:39:32 AM • Biostar G41-M7... • Answered on Feb 23, 2016
My mother board doesnot attach my speakers
Hello you can downlaod the driver here:http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=421#dlSelect the right diver for your windows system.Connect the speaker jack to the green outlet, on the back panel:1_26_2013_2_24_05_pm.jpgRemember to set the speakers on, and make sure the volumen is not turned down low or muted.Good luck
1/26/2013 2:27:19 PM • Biostar G41-M7... • Answered on Jan 26, 2013
Biostar g41 m7 wont power up after installing cpu
have you an ATX/BTX PSU?with 24pins ATX + 4pins P4 connector?if you haven't that it's normal that's don't workelse your PSU 5Vsb or/and your motherboard are dead
11/21/2012 4:04:40 PM • Biostar G41-M7... • Answered on Nov 21, 2012
Any kind of mouse & keyboard not support
It sounds like you have drivers missing, (check your device manager) or try looking on the disk that is supplied with the board else contact the board manufacturer. A USB keyboard and mouse should work, if not it could also be your OS installation. Another though is that I hope you are not trying to use your old hard drive setup on a new board, it wont work as it will be looking for the wrong components and main board. A complete re install is the answer if you have done this.or try and replace all the drivers needed for the new board.
6/6/2012 12:25:40 PM • Biostar G41-M7... • Answered on Jun 06, 2012
Need 64 bit usb drivers for my motherboard - a Biostar G41-m7
Hi, intially when you install the chipset drivers from the website http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=421 it will install the USB 2.0 drivers for you as it is already in the package. However, I now currently have the same problem as you as it seems that either a Windows Update or other software has removed this.
5/4/2011 10:50:13 PM • Biostar G41-M7... • Answered on May 04, 2011
HIGH SPEED USB HOST CONTROL
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or if you can see your usb drive but its not working ports(com&lpt)right click update driver check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall then hope this helps don
3/8/2011 2:09:48 AM • Biostar G41-M7... • Answered on Mar 08, 2011
I need i driver audio
Download all drivers of Biostar G41-m7 Drivers
http://exehub.com/biostar-g41-m7-motherboard-drivers-manual-and-specs/
2/17/2011 6:40:26 AM • Biostar G41-M7... • Answered on Feb 17, 2011
Biostar g41-m7 motherboard troubleshoot. I get no
*********** board was damage, change it with new one with same specification
1/20/2011 12:53:35 AM • Biostar G41-M7... • Answered on Jan 20, 2011
I bought Motherboard Biostar G41-M7
There are problems with the video files for this board if you are using windows 7. Firstly I'd try downloading the latest drivers and see if that resolves the problem
12/29/2010 11:44:53 AM • Biostar G41-M7... • Answered on Dec 29, 2010
The computer doesn't detect any
The Motherboard you have talked about supports mostly all the operating systems. If the computer is not detecting the audio driver, most probably the drivers you have installed is not compatible with the Operating System you are using right now. As you have not told what is operating system, I'm not able to find out the proper solution for you. So, I'm giving this link, where you can download all the drivers compatible for your Operating Systems (eg. XP, Vista, Se7en, etc.). For example, if you are using Vista 32-bit, then download the corresponding driver compatible for vista (i.e. Vista x86)....otherwise the driver will never work.
Here is the link for downloading your OS compatible drivers: Download Drivers for Biostar G41-M7
Now install the driver the properly and enjoy working :)
12/25/2010 6:31:24 AM • Biostar G41-M7... • Answered on Dec 25, 2010
Missing sound device or audio device driver. I
This is a direct link to your motherboard drivers
Download On-board audio ,for your wanted operating system .
10/8/2010 8:39:44 AM • Biostar G41-M7... • Answered on Oct 08, 2010
Failure in saving BIOs I have
Enter BIOS SETUP.
Choose Load Factory Defaults.
Save/Exit.
Or, since the motherboard is less than one week old, it has a warranty. Exercise the warranty, to get a replacement motherboard.
8/2/2010 3:47:48 PM • Biostar G41-M7... • Answered on Aug 02, 2010
try this one
3/23/2010 7:03:21 AM • Biostar G41-M7... • Answered on Mar 23, 2010
When I start the system is not video display
There may be problem in Monitor or VGA Card. When you Turn on PC the Monitor light is green after 10 second if It will be orange . It means your monitor is alright . but problem in you VGA Card. When the PC turn on there is any beep. If no beep then your RAM is alright. Problem in VGA Card.
3/21/2010 7:37:53 PM • Biostar G41-M7... • Answered on Mar 21, 2010
Biostar i945cm7b
best is noobs avoiding UEFI and 945 is 2005 tech, not modern UEFI bios .at all but do ask maker this. but 945 ended there.
6/6/2022 1:34:56 PM • Biostar... • Answered on Jun 06, 2022
A78LFM2S-03-62007434503862
no question asked.
6/6/2022 1:24:15 PM • Biostar... • Answered on Jun 06, 2022
Mainboard Vestel 14MB02-03 no power
posted to computer repair help, PCwhat computer is this, not toldVestel 14MB02-03 (mobo labels useless)Vestel made this mobo under contract to an OEM PC maker,. like BIOSTAR? or who? not told really.Vestel does not sell PCs ! google shows no hits (zero). posted wrong PC model?ahhhhh coded words off mobo white painted silk screenssureI see one hit on that number alone and shows LAPTOP PC MOBOclearlyok , why post mobo models. and not real maker of PC laptop model, did you somehow lose the laptop casings.??>???????????odd odd post this is, like that. we fix PC by makers name and real models. not mobo codes. sorrythe model is on the bottom tab on laptops oldor in bios screen 1 toldnow and answer for laptops old. 1: big battery dead and worse shorted making PC dead, remove it run on AC power pack only,see it works.2: coin cell dead, sure it is that old replace it.3: any of up to 20 other modules inside shorted out.4: stuck in sleep mode dead, push power button for 10 seconds and release, runs now?5: LCD CCFL back lamps dead, use a flash light pointed to screen to see data turned on, if seen the CCFL is dead.(aka, background light tubes)
6/6/2022 12:42:55 PM • Biostar... • Answered on Jun 06, 2022
Audio Adapter ESS Technology ES1938/ES1941/ES1946 Solo-1(E) AudioDrive for windos 7
no PC told no OS told but it was for XPbiostar ended support. windows 7 is oct 2009 OSthe old XP driver is here.https://www.majorgeeks.com/files/details/ess_sound_card_es1938es1946_(es1969).html2006 sound cards. it is PCI not PCI-expressso is useless on all modern PC>but since you imply it fits to a PC the PC is a relic and not told the chip sets on the card are not supported by them maker of the chips so is double dead.(product line not maker)https://www.esstech.com/as you see no es1938 era support.if you google things that do not exist the prize is a nasty virus, here is a short test for w7 just for you.the waybackmachine.com shows https://www.esstech.com/going dead (for legace) 2007so dead 2 years before w7 was released.XP lasthttps://web.archive.org/web/20070202023729mp_/http://www.esstech.com/techsupp/drivers.shtmas you can see the FTP links to the drivers are dead.for ever and ever.now to w7 year, 2009 dec, 2 months from w7 releasetiming is everything , no?the endhttps://web.archive.org/web/20091213143106/https://www.esstech.com/they ended all legacy then./ that means so did biostar. with no base drivers it ends.RIP ESS legacy.
5/17/2022 7:12:49 PM • Biostar... • Answered on May 17, 2022
Biostar G41-M7 Motherboard - Socket 775, Intel G41, MicroATX, DDR2, PCIe, USB 2.0 (802700502491) Logo
22 questions posted
Top Biostar Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Biostar Computers & Internet
Most Popular Question
usb port not working
  • Computers & Internet
