20 Most Recent
Intel Classic DG43GT Desktop Board - G43 Express - Socket T - 1333MHz, 1066MHz, 800MHz FSB - 16GB - ... (735858209175) Motherboard Questions & Answers
I'm not getting smooth video
What you need to do is to purchase a decent graphics card, any-thing better than a Nvidia 9600, thats a PCI-Express x16 2.0 graphics card.
There are Nvidia and there are AMD based cards. Both are good.
Remember that you get what you pay for so a cheap card, is not going to give you a great performance.
Go to a computer store and have a look at what they have on offer, remember to get a good make like ASUS, MSI, Gigabyte, etc...
Maybe try an Nvidia 240GT or 250GT, remember also that is your GPU is too power-full the rest of your computer system will become a bottle neck. Meaning that your system will not be able to fully utilize your graphics card.
Use You tube as a tool.
Search Linus Tech Tips for good reviews and computer info.
Take care!
damnor01
My pc[INTEL DG43GT motherboard] doesnt
Your computer should be switched off at the plug only, the switch on the computer power supply can remain on. No damage will occur. This means that to turn your computer on all you need to do is plug it in, power on at the plug and then push the switch on the computer to turn it on.
I have seen this problem before, I am not sure if it the power supply that is causing this problem. I use Cooler Master they perform well and are priced right.
damnor01
I have recently updated the
Ok, you've got your work cut out for you here. Several ways to approach this problem.
1st. Reset the existing bios, simply remove all power from the system then simply remove the bios battery located on the physical mother board. Be careful not to touch any connectors or circuits as you can easily "fry" the mother board with static discharge. Once battery is out wait about 30 seconds then replace the battery ( watch the polarity and make sure to put it back in the way it came out and dont bend/break the contacts), and this should put the motherboard back to its factory settings. There is a bios reset built into the mother board and unless you know where it is and how to use it you'd be safer just to remove the battery.
2nd. Completely erase the hard drive using a military grade eraser program (similar to DiscWasher brand). Don't waste your time using the format that comes with Windows to do this the 1st time as it does not clear files in the parameters (hidden part of Hard Drive). A military grade eraser will take some time to run like maybe 1 to 2 days pending on how large your drive/s are. You could opt for a quick wipe of drive using 1's and 0's which would only take about 2 hrs pending on drive size. Windows will format the drive which it must do, so let it run its course as Windows will see the drive as being new and will reset the parameters as new at this time. If this works then there you go Windows should install now. (don't have a HDD wipe program? I can send you a copy of mine if you need it) You will need a cd burner and blank cd to make a copy of the program. I can send you to get the program and you will need to make a disc to run it from as it will not run from a flash drive or floppy
If still not installing:
Check/replace your bios battery (about $3.00) these batteries are only good for about 3 years but can die after a few weeks, some batteries have lasted 10+ years pending many variables. I believe the batery should read 1.5 volts dc on a volt meter but no less than 0.9 volts dc.
If battery was not problem and you still can't install Windows 7, well now this is gonna be aggravating as heck...
You will need to roll back your bios as this mother board was not designed to run anything over XP sp2 but works at its best with Windows 2000 pro.
This is very time consuming so if you need the info on rolling back the bios let me know and I'll post it. Let us know how it goes and Good Luck!
How long does the Intel i7-930 processor expected to last?
The best way to prolong life of a computer is to blow out dust from the case and cooling fins and power supply regularly, at least every year. That prevents overheating - a primary cause of component failure. Do not overclock.
Do periodic full disk backups and intermediate new file ones. Leapfrog between two external disks. They are cheap. Protect them from fire.
Laptops - same story,, do not block cooling holes by putting on a blanket while lounging. And turn off machine before blowing out dust. Do not use full PSI compressor air! maybe 20 PSI...
Intel D865GVHZ Motherboard won't boot into anything but will turn on
If your Intel D865GVHZ motherboard is not booting and you've tried replacing the CMOS battery, resetting it, reseating RAM, and changing the PSU, it may indicate a more serious hardware issue. You should consider checking the following:
1. Check the monitor: Ensure that the monitor is functioning correctly by trying it with another computer.
2. Check the connections: Verify that all cables, including the power and video cables, are securely connected.
3. Inspect for hardware failures: Check for any visible signs of hardware damage or loose components on the motherboard.
4. Test with minimal hardware: Disconnect all unnecessary peripherals (e.g., external drives, graphics cards) and leave only the essentials connected (CPU, RAM, power, and monitor) to rule out any conflicts or faulty hardware.
5. Try a different RAM: If possible, test with different RAM modules to rule out faulty memory.
6. Listen for beep codes: If your motherboard has a speaker, listen for any beep codes during startup, as they can provide clues about the issue.
7. Inspect the CPU: Check the CPU for any damage or bent pins, and ensure it's seated correctly.
If none of these steps resolve the issue, it's possible that your motherboard or other critical components may have failed, and you may need to consider a replacement or professional diagnostics to pinpoint the exact problem.
Smart response technology
Intel Smart Response Technology (SRT) is used for SSD caching to improve system performance. To use it successfully, here are some steps to consider:
1. SSD Compatibility: Ensure that your SSD is compatible with SRT. It should be a SATA SSD.
2. BIOS Settings: In the BIOS, set the SATA mode to RAID (not AHCI or IDE) before configuring SRT. Make sure your motherboard supports SRT as well.
3. Driver Installation: Before enabling SRT, install the latest RAID drivers provided by your motherboard manufacturer.
4. Backup: Backup your important data because enabling SRT involves data migration.
5. Enable SRT: In the BIOS, set the SRT mode to "Enhanced" or "Maximum" depending on your preference.
6. Initialize SSD: Initialize and format the SSD through Windows Disk Management.
7. Install Intel RST: Download and install the latest Intel Rapid Storage Technology (RST) driver and software for your chipset.
8. Enable SRT in RST: Open the Intel RST software and enable SRT. You should see an option to accelerate your HDD with your SSD.
9. Reboot: After configuring SRT, reboot your system.
10. Verify: Check if SRT is working by opening the Intel RST software. It should show your SSD as a cache for your HDD.
If you're encountering crashes or issues, it's essential to ensure compatibility and follow these steps carefully. If the problem persists, consider seeking assistance from your motherboard manufacturer's support or Intel's support, as it could be related to specific hardware or software conflicts.
How can I troubleshoot a slow computer performance?
The end part of your question makes it sound like an advert.Download and run the Free version of CCleaner. Remove TSR (terminate and stay resident) programs on start up. These are the programs that run in the background.Download CCleaner 6 For Free - Make Your PC Faster & Saferccleaner.comhttps://www.ccleaner.comClean Temporary Files, Optimize & Speed Up Your Computer. Download Now. The No. 1 Tool for Cleaning Your PC. Download CCleaner now. Browse Solutions. View Products. Multiple Payment Options...
The Green led on the motherboard is ON, and the Intel D915gav won't turn on even though it was working well the day before.
There are several possible reasons why your Intel D915gav motherboard won't turn on, even though the green LED on the motherboard is on. Here are some troubleshooting steps you can try:
- Check the power supply: Make sure the power supply is turned on and connected properly to the motherboard. Verify that the power cable is securely plugged into the wall socket or power strip and into the power supply unit. Also, check if the power supply is providing the correct voltage to the motherboard.
- Inspect the RAM: Check if the RAM is seated properly in the slots. Remove the RAM and re-insert it, ensuring it's seated firmly in place. You can also try booting with one RAM stick at a time to see if one of them is faulty.
- Check for loose connections: Check all cables, connectors, and wires to ensure they are properly seated and secured. Make sure there are no loose wires, frayed cables, or damaged components.
- Test the power button: If the power button on your computer is not working, the motherboard won't turn on. Try connecting the power button pins directly to the motherboard to see if it turns on.
- Clear the CMOS: Try clearing the CMOS memory to reset the BIOS settings. This is done by removing the CMOS battery for a few minutes, then re-inserting it and restarting the computer.
- Check the CPU: Make sure the CPU is seated correctly in the socket and that there is no thermal paste residue between the CPU and the heatsink. If there is, clean it off and reapply fresh thermal paste.
If none of these steps resolve the issue, it's possible that the motherboard or another component has failed and may need to be replaced.
Hovedkort: Lite-On Tech. 08FCH (mPGA 478)
Det ser ut til at hovedkortet ditt er ganske gammelt og ikke lenger st?ttes av produsenten, og det kan v?re utfordrende ? finne drivere for det.
Du kan pr?ve ? s?ke etter drivere p? Lite-On Techs nettsted eller p? produsentens nettsted for hver av de komponentene du nevner (Multimedia Sound Controller og Intel 82865G Graphics Controller).
Alternativt kan du pr?ve ? bruke en driveroppdateringsprogramvare som kan skanne systemet ditt for ? finne og laste ned de manglende driverne automatisk. Imidlertid b?r du v?re forsiktig n?r du laster ned og installerer driveroppdateringer fra tredjeparts nettsteder, da de kan v?re up?litelige eller inneholde skadelig programvare.
Mp4 player not working
Check your MP4 player's system requirements.
Some MP4 players are only capable of working with certain
operating systems and hardware, so refer to your player's documentation to
ensure it is capable of functioning with your PC.
Change the USB port your MP4 player is connected to if you
have confirmed your PC can function with your MP4 player.
Disconnect other USB devices, and try connecting your player
to another USB port if you are still having problems.
Try restarting your PC if it is capable of working with
your MP4 player.
Restarting your PC resets non-functioning USB ports, which
may be your problem.
Make sure your USB cable is connected properly.
If your player requires you to install drivers, make sure
you install them.
Try connecting your player to another PC to see if the new
PC recognizes it.
If it does, chances are your computer does not support the
hardware necessary to run your player.
Reset your MP4 player if your PC is still unable to
recognize it.
Resetting your player varies depending on the manufacturer
and model, so refer to your player's documentation.
Contact your player's manufacturer if you are still unable
to get it to work with your PC.
http://applestore.altervista.org/mp3mp4.pdf
