20 Most Recent
Toshiba Satellite L305D Notebook Questions & Answers
My laptop will not display on my tv
Have you been in and executed the screen sharing within in 'Control Pane'/Display/settings tab' in that box, there should be a option to select share screen. Your laptop will be one, the tv will be the other. Click on 'identify screens' each should have a number either 1 or 2.When you do share screens, you need to 'slide them' over with your mouse. It will be there...
3/2/2013 7:55:32 PM •
Toshiba...
Answered
on Mar 02, 2013
How wo i restore my
Hi there. Welcome to Fixya
Here's the procedure on how to restore the computer back to factory state:
1. Power on the computer while pressing the F8 key to enter Advanced Boot Options.2. Under Advanced Boot Options, press the Enter key to select Repair Your Computer.
3. System Recovery Options will appear, click Next.
3. Log On as a local user to access the System Recovery Options.
4. Under Chose a Recovery Tool, select Toshiba Recovery Wizard.
Thanks for using Fixya!
9/24/2012 8:47:58 AM •
Toshiba...
Answered
on Sep 24, 2012
Toshiba PSLC8U-03701Q factory restore
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to
hope this helps you
3/19/2012 4:04:15 AM •
Toshiba...
Answered
on Mar 19, 2012
I loaded windows 7 and lost use of webcam
click start right click on computer select properties device manager scroll to image devices expand if you see a yellow question/exclamation mark ? ! or a red X the driver will need to be installed right click on it select update driverhoope this helps
11/21/2011 4:16:18 AM •
Toshiba...
Answered
on Nov 21, 2011
HOW DO I FIND THE
Built in webcams are usually located at the very top of the Toshiba laptop. The laptop will have pre-installed webcam software you can use to operate the webcam.
In Windows go to Start > Programs or All Programs and look for any software with webcam in the title. Start it and this will allow you to use the webcam. If you are using Windows 7 you can click Start and in the search box type "webcam"
-G33k
9/20/2011 12:44:12 AM •
Toshiba...
Answered
on Sep 20, 2011
On boot up I can
Reseat the memory and try it again. If it still doesn't work, what do you hear for the hard drive? Does it just whir to a full spin up, or does it chunk n klunk?
7/7/2011 2:01:16 AM •
Toshiba...
Answered
on Jul 07, 2011
Just wondering how to activate
If the webcam drivers are installed already, then you can install a program called SNAP, its like a photobooth software you can take pictures with it.
3/16/2011 2:25:38 AM •
Toshiba...
Answered
on Mar 16, 2011
I have the toshiba L305d and the screen stopped
If you have a monitor, you can test the graphcs by connecting it to the rear vga of the laptop.
If you then get a picture it can be
1/ loose connection behind screen where the cable goes into the back of the screen.
2/ invertor needs replacing
3/ screen (unusual for screen to go unless it has a hair crack, but does happen.)
Removing /replacing screen is easy enough,
Generally--
there will be screws under some round sticky covers in all corners- perhaps more where catch is.
Then there are screws on each side of the screen to release the screen from the hinge bars.
The invertor is usually at the base of the screen and usually fixed by 2 small screws, and connected via small plugs with leads to screen/motherboard-
It is rarely the screen cable, but this justs fits into rear of screen, and then will plug into the motherboard (often has a small earth lead fixing to base plate with small screw.
Good luck.
baklogic
1/7/2011 11:05:33 AM •
Toshiba...
Answered
on Jan 07, 2011
The screen quit working. the
Have you registered this laptop? if it is still under warranty you should get in touch with Toshiba. it sounds as if the motherboard has gone out. I just replaced one on a HP that had the same problem.
12/20/2010 7:57:44 PM •
Toshiba...
Answered
on Dec 20, 2010
