20 Most Recent
Lenovo G530 Notebook Questions & Answers
Turn off the touchpad on the lenovo g530
You can simply press Fn+F8 key combination. If that doesn't work try to look for a button found on the upper rightmost corner of the laptop panel the press it. Or to make it simple, look for the power button, opposite side of it you will see 4 buttons, the right most button would be for the touchpad, Just press it. It should disable the touchpad and do the same to enable it back.
I have a virus on
hi firstly you will need to press ctrl then press f10 as computer is powered on before windows loads up you will be given options as to a recovery this will wipe your computer completely of virusus and leave it like new make sure to follow all the instructions goodluck
I want the num lock
Turn on notebook, press F1 to enter bios, look for the bootup numlock status, can set to on or off.
Lenovo Y550P stopped charging battery
Check the Power Adapter and Outlet:
Ensure that the AC power adapter is securely connected to both your laptop and a functional power outlet.
If your laptop has an AC power indicator light, make sure it's illuminated. If not, try a different wall outlet (avoid using a power bar) .
Battery Charge Stops at 60%:
If your battery charge stops at 55%-60% and shows a "plugged in, not charging" message, it might be due to a power management setting.
Some Lenovo laptops have a feature that limits battery charging to extend battery life. To disable this:
For models with Lenovo Energy Management, Lenovo Power Manager, OneKey Optimizer, Lenovo Settings, or Lenovo Vantage:
Check if "Conservation Mode" is turned on. If so, turn it off.
If the issue persists, try updating your laptop's BIOS:
Go to the Lenovo support website, download the latest BIOS for your model, and install it.
Reboot your PC and check if the problem is resolved.
Hard Reset:
Sometimes a hard reset can help resolve charging issues:
Shut down your computer.
Remove the battery (if detachable).
Hold down the power button for 30 seconds (with the battery removed).
Reattach the battery, plug in the AC adapter, and turn on the computer. The battery should start charging .
If these steps don't solve the problem, there might be other causes.
How to connect an onn wireless mouse to a lenovo chromebook? i tried doing this 3 times and still wont connect.
Firstly, try turning over your Bluetooth mouse and find the power switch. Make sure it's turned to ON.
You should see the optical light turn on (usually red). Place the mouse back flat on your mouse pad.
On your Chromebook, select the lower right corner of the taskbar. In the window that pops up, select the Bluetooth icon.
If the Bluetooth status is currently off, enable the toggle switch to enable Bluetooth. Once enabled, you'll see a scanning status as your Chromebook looks for active,
nearby Bluetooth devices. When your wireless mouse appears, you can select it to pair and connect to it.
Once your Chromebook has made its connection with your Bluetooth wireless mouse, you'll notice the mouse pointer moving when you move your mouse
Lenovo ThinkPad L510 boot menu disabled
Repeatedly tap the F1 key when the Lenovo, ThinkPad, ThinkStation, or ThinkCentre logo appears, The computer may beep once to indicate that it will boot to BIOS.
How to Enable Boot device List F12 Option
The following example shows a system that has an option to enable or disable the Boot device List F12 Option.
Go into the BIOS to enable Boot device List F12 Option (option is usually under the Startup tab).
