20 Most Recent
Sony VAIO VGN-NW150J/S Notebook Questions & Answers
Vgn-nw150j keyboard Sony Vaio many keys stopped working all of a sudden need help?
Laptop keyboards do deteriorate from time to time. Once any key stops working, it is time for a replacement. Doing so is not difficult. Simply undo the case screws and gently separate the case to expose the keyboard. The keyboard floats inside and lays in the main board. Lift gently and pull out the small flat wire connection. The keyboard slides out and replace with a new board. Place flat cable in port on the main board, lay keyboard on top of chassis, close the top/bottom of case, tighten screws and all done. Go on line for Keyboards.
2/4/2018 10:48:03 PM •
Sony VAIO...
Answered
on Feb 04, 2018
DARK SCREEN SONY VAIO VGN-NW150J
replace the inverter board it connects to the screen and, is usually at the top of the laptop under a panel between the screen hinges
2/4/2013 6:24:26 PM •
Sony VAIO...
Answered
on Feb 04, 2013
How do i replace my
you will have to open the laptop up by removing the screws and possibly the display aswell.
if you have no experience in fixing laptops i suggest leaving this to the local repair shop to be fixed. it requires time and patience.
in the mean time i will try and find a pdf document with step to step instructions
8/24/2012 10:03:06 PM •
Sony VAIO...
Answered
on Aug 24, 2012
Screen is black when it's
Based on the information you have provided, it confirms the issue is related to the internal led lights of the notebook display.
However, I suggets that you connect any other external monitor to the computer to ensure the issue.
If the display is as expected in the external monitor, contact the Sony technical support team to get the internal hardware replaced for you.
Be careful if you are opening the computer, this voids the warranty.
It's always recommended to contact the sony service or any certified technician to handle such cases.
It may cause a more severe damage to your computer and result in shelling out more bucks to get it resolved.
7/12/2011 8:31:28 AM •
Sony VAIO...
Answered
on Jul 12, 2011
Hi, I have Sony Vaio,
HI,
go to following link and click on Download now and get your webcam drivers.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNW150J&upd_id=5051&os_id=49
Please don't forgot to rate if you get the solution.
6/3/2011 4:27:16 AM •
Sony VAIO...
Answered
on Jun 03, 2011
How do i replace my
you can call the SONY Technical support and give them the serial number of the laptop and they will immediately replace the keyboard.
5/30/2011 5:20:56 AM •
Sony VAIO...
Answered
on May 30, 2011
Hi! I installed windows 7
Hey,
Make sure you are downloading the correct driver for your webcam, and make sure that if you are installing 64bit windows 7 that you have a 64bit driver, and same with 32bit (im sure you are, but double check just in case).
If you are 100% sure of that, have a look through the drivers page for your laptop and look for a "chipset" update of some sort.
Hope this helps :)
5/25/2011 1:59:05 AM •
Sony VAIO...
Answered
on May 25, 2011
I cannot recover the bios
You mean you Forgot the Password?
Remove the cmos battery and hook it back in.
Hope this helps.
Cheers!!!
1/6/2011 6:07:05 AM •
Sony VAIO...
Answered
on Jan 06, 2011
Bios unlock
TO UNLOCk your BIOS you have to Disable it..
i ll advice you ro se a laptop technician..
12/21/2010 2:51:46 PM •
Sony VAIO...
Answered
on Dec 21, 2010
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
