20 Most Recent
Toshiba L505D-S6947 Notebook Questions & Answers
I have a L505 Toshiba lap top does It have a
For you to check if it has a backlit keyboard press Fn+Z or go to start/all programs/mytoshiba/utilities/HW setup/and there should me ilumination option. If none of this works, it only means that your laptop does'nt have that features.
3/18/2011 11:12:26 PM •
Toshiba...
Answered
on Mar 18, 2011
My toshiba L505D S6947 keeps turning itself off
Hi, you can try to clean fan with a compressed air can, if the fan works most of the time this helps and you will not need to take anything apart, just pick up one at your local electronic store, follow the safety instruction on the can and spray all the air ways starting with the openning under your fan, but start SLOW and gradually increase the air flow and be very careful not to let the air pressure break the fan fins by sudden changes in the air flow... It should be fairly easy and maybe it will be agood idea if you try the air can on some of the larger electronic appliances first till you get used to it, be careful because the can gets very cold after a while :) Hope that Helps
2/4/2011 1:56:21 AM •
Toshiba...
Answered
on Feb 04, 2011
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
on Mar 26, 2024
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D.
If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM •
Toshiba...
Answered
on Oct 11, 2023
