20 Most Recent Samsung N310-13GB Netbook Questions & Answers
It sounds like the Hard Drive has failed. You an get a new drive for $30 from Amazon or BestBuy. Replace the hard drive and install an Operating system of choice. The Old drive may not be accessible, thus be prepared to accept the loss of data as all may be lost.
Samsung... | Answered on Feb 06, 2018
You seem to have isolated the problem to the microphone. If the opening to the microphone is not blocked by dust or lint or some other substance then the microphone itself will need to be replaced. You might be able to verify the function of the microphone with an oscilloscope or volt meter, or simply replace it. Sorry there is not an easier solution.
Samsung... | Answered on Nov 21, 2017
try this as your password " phoenix, PHOENIX, CMOS, BIOS" atleast one should work
Samsung... | Answered on Apr 07, 2017
The problem with your Netbook seems to be that you have turned "NUMBER LOCK" or "NUM LOCK" on. This causes some of the letter keys, e.g U,I,O,J,K,L,M to be printed as numbers 0,1,2,3,4,5,6.
To turn this off, hold down the "FN" key (near the bottom left of the keypad) and then press "F11" and then release both keys.
Please try this and post back if you need further assistance.
Regards,
BElectric
Samsung... | Answered on Jan 31, 2015
What netbook is it?
Samsung... | Answered on Oct 31, 2013
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Samsung... | Answered on Feb 05, 2013
Use the repair option to reinstall Windows 7. This should load on top without wiping system.
Download this tool and make a USB Windows 7 Installation drive.
http://www.microsoftstore.com/store/msstore/html/pbPage.Help_Win7_usbdvd_dwnTool
Samsung... | Answered on Oct 20, 2012
I personally use AVG rescue disk and have successfully installed it onto a USB stick using WinSetupFromUSB http://code.google.com/p/winsetupfromusb/downloads/list
use the PartedMagic/Ubuntu Desktop Variants /Other G4D comp. ISO option.
Sorry to half answer your question, I have tried to run the Avira rescue cd with this method and not been successful.
Hope that helps
Christopher
Samsung... | Answered on May 15, 2012
You need the HDD master password and you can get it here http://www.unlockbiosrecovery.com/Unlock_Samsung_HDD.php I repair laptops and use them a couple times a month and it has never failed. They provide bios master passwords and HDD master passwords service for most laptops from Dell, HP, Samsung, Fujitsu, etc
Samsung... | Answered on Sep 02, 2011
http://unlockbiosrecovery.com/Unlock_Samsung_Bios.php can supply you with the master bios password for you Samsung Netbook for just $20 plus they guarantee it to work. I use them in my work as a laptop repair tech and they always work.
Samsung... | Answered on Aug 25, 2011
You need to install the microphone driver which is available on Manufacturer's website along with that you also have sound drivers install that too.
Hope this helps you to solve the issue. Please do vote or provide feedback on this solution as it will be appreciated.
Thank you
Gowtam R
Samsung... | Answered on Jun 25, 2011
remove battery, after it one press turn on buttom, then put battery, swithch charger and turn on.
Samsung... | Answered on Jun 13, 2011
Samsung N310-13GB Netbook Logo
50 questions posted
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Computers & Internet
Most Popular Question
evereyone
  • Computers & Internet
