Hi, don't worry. windows password unlocker can help you.
Just download it from http://www.passwordunlocker.com/products/wpu.htmlThere are free methods as well, you can search for them in google. Manual changing of password requires an advance user. You can also reset your netbook using recovery disk. Please see this: http://www.ehow.com/how_5833609_restore-acer-aspire-one-series.htmlTo reset your bios password please refer to either one: !BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore. CmosPwd - Cmos password recovery tools Please let me know if it was helpful. Thanks
The best place to buy a battery for your laptop is eBay. Once the site comes up just put in the search box something like Acer Aspire One battery. Click the link below and type in the search box "Acer Aspire One Netbook Battery" (without the quotes) and click Search. When the search results come back Select to only see the Buy It Now merchandise and Sort the list by lowest price first. The first couple of items will be ac adapter and power cord, but once you hit the prices in the $20 range you will start seeing the battery. Click the link belowto see a all the batteries.http://www.ebay.comThe link below will take you directly to one that I selected that costs $23.99 including FREE Shipping. Please note that the battery fits the Acer Aspire One ZG5, A110, A150, D150 and the D250 which is your model. http://www.ebay.com/itm/New-Netbook-Battery-for-ACER-ASPIRE-ONE-ZG5-A110-A150-5po-/250979671222?pt=Laptop_Batteries&hash=item3a6f8ddcb6
Restore windows XP in safe mode:To start System Restore using the Command prompt, follow these steps: Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt. Use the arrow keys to select the Safe mode with a Command prompt option. If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER. Log on as an administrator or with an account that has administrator credentials. At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER. Follow the instructions that appear on the screen to restore your computer to a functional state.Use system utility tool like RegInOut to repair corrupt registry and windows files.
You can get a Manual at this site for free.
http://www.manualowl.com/p/Acer%20Computers/AOD250/Manual/82706Make sure it is turned on.Then Set up the configurations to look for known sources like a Wi-Fi Cafe.Next is the hard part. You may have to check your firewall settings and even disable them. But read page 49ish of the manual.
u may need its software to see the images and take videos..
you can download it from
http://www.google.co.in/url?sa=t&source=web&cd=1&ved=0CBkQFjAA&url=http%3A%2F%2Fwww.camersoft.com%2Fwebcam-capture.html&ei=h9PoTNH8PIqmcNvr8ZUK&usg=AFQjCNG3KsxYeJS7VAoP_8ORPs9u4RwN8w&sig2=4zew77O2PapjNr6JyphInA
If you have a driver disc or can download and make one, I would install the internet drivers. And if at all possible, get a program called glary utilities which is a registry error fixer and optimizer.
Question edited for clarity and toss in a few CAPS.
Question moved to Acer Aspire category.
There a few issues that can cause this, the obvious one is that the battery has failed internally, but it can also be a charging software issue. Try this. Unplug from the mains supply. Remove the battery. Leave the computer for 2 hours. Press and hold the power button for a full 2 minutes. Replace the battery, plug back in, count to 10 and power it back up.
Has the motherboard battery ever been changed? They are critical to the health of the motherboard and the machine in general.
what password computer or outlook
Reset an Outlook password to keep your program secure.
A
Microsoft Outlook password keeps your email account secure from unwanted
intrusion.
When you wish to reset your Outlook password, you must
perform a multistep process to change your password first with your Internet
Service Provider (ISP).
The password with your ISP mail server must be the same as
the password you set in your Outlook program in order to send and receive
emails.
Call your ISP and request a new password for your account.
Write down the password after you receive it to ensure you
do not forget it.
Open your Outlook program, click the "Tools" tab
and then select "Email accounts."
Select "View or change existing email accounts"
and then press "Next."
Highlight the email account you wish to change (if you
have more than one email account) and press "Change."
Enter the new password you just received from your ISP
into the appropriate fields (entering it twice).
Place a check mark beside "remember password" if
you want Outlook to remember your password each time you log in.
Click "Test Account Settings" to make sure your
account works with the new password.
Press "Finish."
I forgot my Outlook password
http://office.microsoft.com/en-us/outlook-help/i-forgot-my-outlook-password-HA001113690.aspx
If you have no internal hard drive installed you won't get it to work correctly as the hard drive is where the data is stored for the operating system.
Estimado Carlos,
Cuando la PC se apaga poco tiempo despues de terla prendido puede ser una senal de sobrecalentamiento del procesador. Si es una PC desktop, puedes verificar si el disipador de calor de aluminio y su ventilador estan colocados correctamente sobre el procesador y si el ventilador esta' funcionando. Si es una laptop, debes verificar si cuando la prendes el ventilador de las rejitas de ventilacion esta' suenando. Un ventilador que este' parado o con baja rotacion puede ser una de las causas del sobrecalentamiento. Pero, en los dos casos, si no es problema del ventilador del procesador, lo que hay que hacer es lo siguiente:
1 - Desarmar la computadora, y sacar el disipador de calor com mucho cuidado de sobre el procesador;
2 - Limpiar bien entre las ranuras del disipador de calor, sacandose todo el polvo y suciedad del mismo ya que el polvo ayuda a mantener el calor y sobrecalentar el procesador;
3 - Limpiar muy bien las rejillas de entrada/salida de aire, sacandose todo el polvo y suciedad,
4 - Rearmar el disipador sobre el procesador, pasando entre ellos una delgada camada de pasta termica plateada, que se puede comprar en tiendas de suminsitros y partes de computadoras (NOTA: no instale el disipador sobre el procesador sin pasar la pasta termica, porque podra' seguir sobrecalentandose);
5 - Rearmar la computadora.
Caso usted no tenga facilidad en armar y desarmar la computadora, seria bueno contactarse con un tecnico de su confianza para hacer ese trabajo para usted.
!Espero que esa respuesta pueda haberle sido util!
PD.: Como ese sitio web solamente accepta caracteres en Ingles, la acentuacion no puede ser utilizada normalmente...
Saludos,
Miguel Luiz Martins
OucH no acer real model PC told at all wow hard nut to crack that, I sure can not guess that ...The case told only helps if power on button is wrongor the PSU is wrong. I moved this to acer forum. as the mobo matters.Q1;never worked before by you,? this acer mobo by you?or found it used and dead.? used mobo come good bad or a wreck. (history not told , as in when did fail)the acer.com is the place to look first. for manuals. not told what GPU are you using onboard vga or GPU card or what?All fans spin ? CPU and PSU????if using GPU card that has fan, does it spin too??if case fans do they spin?DoeS DVD tray eject (button hit)?DOES PC beep or flash LED codes?Q2;What VIDEO port class is this "connection"is it:vga, hdmi, dvi or DP ports which one, and where is it? For now only use (if has one) use the VGA port on the mobo , no PCI cards in slots., NO HDD, AND NO DVD DRIVE (JUST UNPLUG THEM FOR NOW) ALL USB THINGS UNPLUG, KEYBOARD LEAVE THERE.MEMORY :pUT 1 stick of ddr RAM only in bank0 channel "A"CPU socket pins bent as seen on ebay endless and sad. below is me guessing what Acer you have.and find this, Acer/GATEWAY ZX4951 or ASPIRE Z3100I read the GW manual check jumpers.the PSU needs 2 power cables to the mobo.4pin power and 24pin (or 20 on legacy)or mobo will be dead. why mess with ACER. (they have no service manuals)put an Asus or Gigabyte mobo there and end this ACER pain,post a photo of the mobo and we can guess what PC it came out of, .......
mute the speakers if still sounds noisy the fan inside is packed in lint and needs to be cleaned out or overeheating is bad news.
why not ask a shop to look into this.
we can take it apart (covers ) and user or stethoscope to hear noise.
a $5 tool that is. and all shops have one or DIY one.
I put my hear to hDD casings me,
i use tube and put it near the fan vent to hear it scream.
there is no other way besides unplugging all that 1 by one to hear it go silent.
this is SOP, vast PC's pack up in lint and fail.
