20 Most Recent Kenmore 24 in. 16693 Built-in Dishwasher Questions & Answers
sounds like the circulating pump. could be a foreign object stuck in the pump impellor. could also be the pump capacitor - cheap part
Kenmore 24 in.... | Answered on Sep 03, 2008
check it has salt in the bottom tank. check the out pipe is not blocked or bent/twisted. check water feed is working and the filter in the line is clear. ( filter is in the machine side of the pipe you need to turn off water and remove the pipe at this end to get to the filter)
Kenmore... | Answered on Jan 09, 2020
You need to remove the arms and check the nylon bushing in the centre. Also check that all of the holes are clean, especially the ones at the outer end as they are the ones that make the arms spin. They should spin freely by hand and not stop for a few seconds.
Kenmore... | Answered on Jan 06, 2020
Remove lower basket and try again
Kenmore... | Answered on Nov 25, 2019
Look carefully at your dishwasher keyboard, to see what key is nearest (above or below) the lighted lock symbol. Usually it's the Heated Dry button. Whatever it is, press and hold that key for 5 seconds. That should unlock you dishwaser and you can now use it normally.
Kenmore... | Answered on Oct 03, 2019
select a feature that is not eco friendly
Kenmore... | Answered on Sep 22, 2019
The manual lists that error code as faulty water supply. I am guessing your heater may be malfunctioning. Try to run it on cold and see if it works.
Kenmore... | Answered on Sep 17, 2019
The first thing to do is visually check to make sure the water connections from the sump assembly to the top spray arm is all in good shape and connected, also make sure the spray arms ports are clear of any foreign material. Make sure that the top rack is seating properly to the water tube in the back of the machine. If this is all good it is possible that the diverter valve is malfunctioning. If it comes down to the diverter valve I would recommend that an authorized repair company assist you as they can be a trick and quite involved.
Kenmore... | Answered on Sep 10, 2019
If you broke a glass, the odds are that a piece of glass has jammed the impeller on the drain pump and the buzzing you hear is the pump trying to run. In order to fix this the dishwasher will need to be removed and tilted back. Be careful not to damage the floor or countertop and the unit should be disconnected from power for safety. Once the unit is pulled out and tilted back the drain pump is easily accessed. Put a cakepan or something under the drain pump to keep the mess to a minimum. Remove the drain pump and remove your broken glass. If you do not feel comfortable with a job as such please use and authorized repair company.
I hope this helps
https://www.bing.com/videos/search?q=kenmore+dishwasher+drain+pump+replacement+video&view=detail&mid=8F6658F65E3A8816B5988F6658F65E3A8816B598&FORM=VIRE
If you go to www.partsdirect.com you should find the answers you need
Water Filters Lawn Garden Appliance Parts
The first question I have is did this issue start after a garbage disposal was installed? There is a plug in a new disposal that needs to be removed. If this is not the case the easiest thing to do is pull the dishwasher out. Be careful not to damage the floor or countertop. Tip the dishwasher back and put a cakepan or something under the drain pump to keep the mess to a minimum.
Remove the drain pump. Make sure you check the impeller is not loose on the shaft or broken and of course clean the ports.
I hope this helps.
Kenmore 24 in. 16693 Built-in Dishwasher Logo
3 questions posted
Top Kenmore Dishwashers Experts
Ron Rak
Ron Rak
Marvin
Marvin
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dishwashers
  • Kenmore Dishwashers
Most Popular Question
will not wash
  • Dishwashers
