20 Most Recent Samsung SP50L6HX 50" DLP HDTV Questions & Answers
Hello, I think I understand the question, your TV is making a beeping sound indicating its time to change the lamp? If so I suggest you go with the original Philips on the link below, to get the brightest image possible.
Samsung SP50L6HX... | Answered on Feb 06, 2014
Google that model number with ballast or lamp ballast to locate the part and its number. Usually the color wheel will not operate if ballast is not working---Lamp comes on and stays on the Ballast is good.
Samsung SP50L6HX... | Answered on Jul 30, 2013
Look to see if this happens at all inputs--tuner and rear first.
This issue is not clear to me---sound is popping or you are hearing a sound from inside the set?
Samsung SP50L6HX... | Answered on Jun 14, 2013
I have the same telly for the last six years and i only changed the lamp two weeks ago i think there a very good telly
Samsung SP50L6HX... | Answered on Jan 22, 2013
If you take the panel off the back of the telly its right in front of you you take one screw out and slide out the little box with the lamp in it
Just Google the model number with "lamp" and you can take your pick of replacement lamps.
Samsung SP50L6HX... | Answered on Dec 19, 2012
Sounds like your color wheel is going out.
Samsung SP50L6HX... | Answered on May 11, 2012
If model number indicated here is correct does it do it on all inputs(tuner ,DVD inputs etc)?
Samsung SP50L6HX... | Answered on Apr 09, 2012
SAMSUNG CODES...0311, 0312, 0338, 0963. ANY ONE OF THESE CODES MIGHT HELP...J PAXTON
Samsung SP50L6HX... | Answered on Jan 22, 2012
The first thing to check would be the status if the lamp especially if you have not replaced it in a while. Old/burntout lamps consure a lot more power than they should there by exerting overload on the lamp driver(ballast) and hence the power supply. So please check the status of the lamp and let me know.
Samsung SP50L6HX... | Answered on Jun 20, 2011
The tv projection lamp inside the tv now it is 1 1/2 or 2 years already,tv in used 4 or 5 hrs everyday?Yes,than the tv projection lamp life have ended,require replacement too.The clickings sounds,it is the board that call the Ballast board it is dead too,the clicking sound mean the Ballast board continueing tried to ignite the tv projection lamp.
Samsung SP50L6HX... | Answered on Jun 14, 2011
The tv LED light on the tv front bazel frame face have the word "LAMP" light up or blinking?Yes.The tv projection lamp been inside this tv like 1 1/2 or 2 years already,tv used it everydays like 4 or 5 hrs daily?Yes.Than the tv projection lamp life are over,that why it dim picture tv now must have it tv projection lamp to be replaced.
Samsung SP50L6HX... | Answered on Jun 13, 2011
this is an inherit problem of this set - - search 'wavy line' and you'll see many samsung sets have this - there is no cure ! use the set with component or hdmi good luck
Samsung SP50L6HX... | Answered on May 05, 2011
Lamp will be the problem if it has never been replaced.
Mats Electronics sells Lamps 1-800-628-1118
Samsung SP50L6HX... | Answered on Mar 10, 2011
Samsung SP50L6HX 50" DLP HDTV Logo
49 questions posted
Muntejaya Ginting
Muntejaya Ginting
Demonic-2011
Demonic-2011
View Most Popular
  • Samsung Televison & Video
Most Popular Question
ballast part no samsung sp50l6hx please
  • Televison & Video
