20 Most Recent
Sharp TUTV322H Questions & Answers
UNDEFINED HAS COME UP ON BOX
Check the aerial connection onto the box is firm and the wire is not pulled tight. If it looks ok disconnect it from the box and connect it to the TV aerial input and then see if the TV can show any channels at all when you tune it in. If there is nothing coming to the TV, the aerial feed or actual roof aerial may be damaged, or not pointing at the transmitter mast.
On my sharp tu tv322h my epg is blank ive tried retuning but its still blank can you help?
This worked for me.....(from the Top Up TV website)
Purge VOD.
Press the menu button
Scroll down to Option 4 and press OK
Scroll down to Option 6 and press OK
In the help menu press 1397 on the remote control quickly and in sequence
Scroll down to the 'Purge VOD Schedule' option (next page) and press OK
Remember the DTR must be either on or left in standby at all times to receive the EPG and programme downloads. • The guide will update at the next scheduled slot (between 11am and 12pm daily).
Updates are also quicker if you change from 14 day EPG to the 8 day version...
Guide > Set-Up (4) > Change box settings (2) > TV guide type (9) > back arrow > Continue (green button)
This recorder box every so
U know basic electronic and have all the tools also can do basic soldering work?Yes,take the unit aparts.Check all the components parts that call capacitors on the circuit board carefully it is dying and leaking.These capacitors parts are alway bulges up or puffing onto it tops.By replacing all these dying capacitors components,than the unit will continue contantly provided correct voltages current to the unit,than it will not shutdown again.
Sharp TU-TV322H failing to make planned recordings
I had this problem aswell! I tried everything but ended up phoneing the help line, when they asked for what frequancies they found out i was picking up different ones form two different stations. I took the ariel out of the back on the freeview box and run a scan for channels (of course it came up with none as the ariel is unpluged but it overwirites and clears the incorect frequencies). Then plug the areil back into the freeview box and run a scan for channels. After doing this i picked up the correct frequencines form the correct station and my recordings actually recorded! If you phone the help line (08444159159) they will tell you what frequencies you should be picking up. I hope this qorkes for you!
How can I make the text sharp on Magnavox model 22ME601B/F7?
- Check HDMI Cable Connection: If you're using an external device like a cable box, gaming console, or streaming device connected to the TV via HDMI cable, ensure that the HDMI cable is securely plugged into both the TV and the external device. A loose connection can cause intermittent resolution adjustments.
- Adjust Picture Settings: Navigate to the TV's menu and check the picture settings. Look for options related to display resolution, aspect ratio, or picture mode. Ensure that the settings are configured correctly for your viewing preferences. Try resetting the picture settings to default and see if the issue persists.
- Update Firmware: Check if there are any firmware updates available for your TV. Sometimes, software updates can fix bugs or issues related to display resolution adjustments. You can usually check for updates in the TV's settings menu or visit the manufacturer's website for instructions on how to update the firmware.
- Check Signal Source: If you're experiencing resolution adjustments while watching content from an external device, such as a cable box or streaming device, make sure the signal source is sending a consistent signal. Issues with the signal source can sometimes cause the TV to adjust its display resolution.
- Reset TV: Try performing a factory reset on your TV to restore it to its original settings. Keep in mind that this will erase any customized settings and preferences, so you may need to set up the TV again after the reset.
- Contact Magnavox Support: If the issue persists after trying the above steps, it's possible that there may be a hardware problem with the TV. In this case, it's recommended to contact Magnavox customer support for further assistance or to inquire about repair options.
By following these troubleshooting steps, you should be able to diagnose and resolve the issue of your Magnavox TV constantly adjusting its display resolution.
Hope this helps
