20 Most Recent LG Rumor 2 Cell Phone Questions & Answers
0answers
0answers
LG Rumor 2 turning on and off.
First, make sure if this problem appear after you install any APP, if so you can try to brush system to fix it.Else maybe the following cases:1, mobile phone motherboard leakage lead the current too large.2, The inside circuit protection of the lithium battery is too sensitive, so it power off when circuit is large.3, the battery itself is aging.4, Battery contacts are dirt-bit, causing bad power supply.5, The engagement between the battery and the phone is easy to loose bits. (try to remove the back case and press the battery then try to turn on it to see if it also turn off and on). If so, just make a piece of paper to stand the battery upOf course, don't forget to see if the power button is back to its own place
7/2/2013 9:05:23 AM • LG Rumor 2 Cell... • Answered on Jul 02, 2013
Black screen
You may have water damage to your phone. Try placing your phone into a bag of rice, the rice will absorb the moisture, and will hopefully fix the problem. If the phone is damaged beyond household repair you are probably going to have to replace it.
6/2/2013 5:36:21 AM • LG Rumor 2 Cell... • Answered on Jun 02, 2013
Lost phone can I get phone numbers
Contact Sprint Customer Care. 1888-211-4727. Also if you go to www.sprint.com and login to your account you may be able to view a list of sent/recieved phone numbers. There will not be any names attached to these numbers though.
3/11/2013 10:38:48 PM • LG Rumor 2 Cell... • Answered on Mar 11, 2013
Rumor 2- people can not hear me- i can hear them
This is a mic problem, you need to show some official repairer to fix,but temporary you can use bluetooth or headphone that will be useful.
7/6/2012 10:23:58 AM • LG Rumor 2 Cell... • Answered on Jul 06, 2012
Codes for a rumor2 sprint phone
2945#*# this will help you.
6/20/2012 10:44:48 PM • LG Rumor 2 Cell... • Answered on Jun 20, 2012
Bought new battery for cell phone, wont charge or turn on
did you try a new charger not the best solutinon
6/11/2012 6:21:59 AM • LG Rumor 2 Cell... • Answered on Jun 11, 2012
How do i turn the bluetooth feature on for my rumor 2
  • Insert a microSD card into the slot on the right side of the phone.
  • 2 Connect the phone to your desktop with the USB cable.
  • 3 Select "Transfer Music" on the phone by pressing the "OK" key after highlighting "1 Yes" on the display.
  • 4 Go to your desktop and use Windows Explorer, which will have now opened up, and you can drag and drop files from the desktop to the phone just like another directory.
Use the Rumor Bluetooth to Connect to Your PC or Other Bluetooth Device
  • 1 Set your secondary Bluetooth device into the pairing mode.
  • 2 Open the "Tools" menu on your phone by first making sure it is in the standby mode and the slide is closed. then press the "OK" key and select "Tools."
  • 3 Select "Bluetooth" and press the "OK" key to choose "Pair with Hands-Free." If "Bluetooth Wireless Technology" is turned off follow the prompts to turn it on by pressing the "Left Soft Key."
  • 4 Highlight secondary Bluetooth device on the list of found devices and press the "OK" key.
  • 5 Enter "0000" pin code and press the "OK" key to initiate the pairing process.
  • 6 Enter the device's name and press the "Left Soft Key" for "Save."
  • 7 Connect to your device by pressing the "Left Soft Key."
3/2/2012 8:34:11 AM • LG Rumor 2 Cell... • Answered on Mar 02, 2012
How do i turn on bluetooth feature on my rumor 2
    • 1 Turn on the Bluetooth-enabled device and enable it to be in "Discovery" mode. Check the owner's manual of the device to learn how to put it in "Discovery" mode.
    • 2 Press "Menu/Ok" on the LG Rumor2, which is the middle button on the phone.
    • 3 Press " * " to access the settings menu.
    • 4 Press "1" for the Connections menu.
    • 5 Press "2" for the Bluetooth menu then press "1." Press "Yes" when prompted to turn on the Bluetooth feature. A list of available devices appears in the menu.
    • 6 Highlight the listed device, which should be showing.
    • 7 Click "Ok."
    • 8 Enter the passkey provided in the owner's manual of the Bluetooth device. The standard passkey is "0000." The Rumor2 is now paired with the Bluetooth device.
    • 9 Press the "Call" key on the phone or the "Call" button on the Bluetooth device to answer calls through a Bluetooth headset while paired.
3/2/2012 7:36:15 AM • LG Rumor 2 Cell... • Answered on Mar 02, 2012
Lg rumor 2 keeps flashing hello screen
Most of the time , a master reset will solve most problems. Here is how you do it with an R2.Go to Virgin Mobile USA. Click on help. Click on phone manuals and guides . Click on the R2 model. Click on user's manual. Go to page 70. Go to how to reset all settings. Follow the instructions. It should return your phone to original factory settings. If this does not work, call VM or take it back to where you bought it from. Hopefully you have the receipt and maybe you can get an even exchange or refund. Warranties on cell phones do not cover water damage.Hope this will help :)
1/26/2012 8:47:52 AM • LG Rumor 2 Cell... • Answered on Jan 26, 2012
LG Rumor 2 Cell Phone Logo
111 questions posted
Top LG Cell Phones Experts
David Shaub
George Etukudo
mike rigsby
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
RUMOR LG
  • RUMOR LG
Most Popular Question
rumor 2 people not hear me hear
  • Cell Phones
