20 Most Recent Nokia 7610 Supernova Cell Phone Questions & Answers
HI DEAR
JUST INSTALL A SOFTWARE CALLED FEXPLORE IN UR PHONE(DOWNLOAD FRM HERE WWW.USEFULLSOFTZ.XTGEM.COM).THEN OPEN FEXPLORER GO TO E DRIVE THEN IN SYS FOLDER THERE U WILL SEE A FILE CALLED MMCSTOE OPEN IT WITH UR NOTEPAD.U WILL GET UR PASSWORD THERE
FOR MORE TIPS AND TRICKS EMAIL ME [email protected]
Nokia 7610... | Answered on Feb 21, 2017
I've ever had this problem too so I called the Nokia centre and they told me to go to the Menu-Setting-Restore Factory Setting. Done it's fixed by itself. Anyway sometimes you couldn't activated the camera when the battery is running low.
Nokia 7610... | Answered on Nov 03, 2013
PLS NEW CAMERA SOFTEWEARE INSTALASION
how this nokia 7610 memoir card remove password
Nokia 7610... | Answered on Oct 16, 2013
hi
visit on this site http://www.unlockme.co.uk/master.php
after visiting on that site you have to enter your phone's imei no. in the textbox which are given on that page
after entering your imei no. click on get master code button to get your phone's master code
Nokia 7610... | Answered on Sep 03, 2013
Dear please reinstall its software. Problem will be quickly solved. Thanks
Nokia 7610... | Answered on Jul 01, 2013
Corrupted software
It isn't often that Apple gives specific directions about how to fix your problem! Restoring the iPhone 4 will erase everything on it, so make sure everything on the iPhone 4 is stored elsewhere prior to restoring. To restore, connect your iPhone 4 to a computer with iTunes installed. Click "Restore" on the iPhone 4 summary page (click on your iPhone icon on the left menu to find this page). Follow the directions to restore. If your iPhone 4 displays the text "Please wait. Very Low Battery," leave it plugged in. This charges the iPhone 4 enough to be able to restore. If the iPhone 4 hangs on this screen for long periods of time, you may need a new battery.
Force restore mode
If your iPhone 4 is hanging with an Apple logo, or exhibiting some other software problem that prevents iTunes from recognizing it, you can force it into recovery/restore mode and then use iTunes to restore the software.
If the device is powered off, plug one end of your USB cable into the iPhone 4 and leave the other end disconnected. Press down on the Home button, and keep holding it down while you plug the USB cable into your computer. After 5-10 seconds, you should see a "Please Connect to iTunes" image on the iPhone 4, and iTunes should prompt you to restore the software; follow the prompts and the instructions given above.
If the device is powered on, hold down both the power and home buttons until the device reboots and displays the "Connect to iTunes" image (generally, 5-15 seconds).
God bless you
Nokia 7610... | Answered on May 24, 2013
Hi, If you have forgotten the security code of your Nokia 2610, You can do a master reset to it. This could restore your phone with default factory settings. So the security code also changes to default 12345. You can get the master reset code for a Nokia 7610 from www.unlocking4free.com for free. Good luck mate.
Your mobile screen connector point must be having loose or a faulty screen. Best it will be to take it to the servicing center.
Thank you for asking on fixya.com
Nokia 7610... | Answered on Mar 21, 2013
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Nokia 7610... | Answered on Nov 13, 2012
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nokia 7610... | Answered on Nov 10, 2012
Hi what kind of lock code are you asking for? Is it a phone lock or a network lock?
If it is a phone lock, You must do a master reset for your Nokia 7610. This could restore your phone with default factory settings.
If it is a network lock, You need to enter the unlock code. You can get the unlock code either from your network provider or from any trusted vendor online. For example you can get the unlock code from www.unlocking4u.com/nokia-7610-supernova/rs6wp9/ at affordable cost.
Here are the steps for unlocking a Nokia 7610 SUPERNOVA,
1 - Switch on your Nokia 7610 SUPERNOVA without any sim card.
2 - Don't bother as to what is displayed on your Nokia 7610 SUPERNOVA.
3 - Compose #pw+CODE+1#.
4 - The Nokia 7610 SUPERNOVA would then display the message "SIM Restriction Off" and will be unlocked!
Nokia 7610... | Answered on Sep 14, 2012
If you forget the security code means get the master reset code for that one, master unlock code is a code that completely resets your phone, removing any security locks , get the code from this site www.unlock-free.com/nokia-master , it has the best services for the master reset code for your Nokia 7610 model mobile.....I hope that it may helpful to you....
Nokia 7610... | Answered on Aug 18, 2012
Ok there is only one solution, Just change the speaker (Ringer).Contact your nearest mobile repairing shop.Thanks for visiting fixya
Nokia 7610... | Answered on Jun 20, 2012
Nokia 7610 Supernova Cell Phone Logo
137 questions posted
Popular Products
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
SANTHOSH
Marvin
Marvin
View Most Popular
Nokia Cell Phones
  • Nokia Cell Phones
Most Popular Question
network not
  • Cell Phones
