20 Most Recent Motorola TLKR T5 Two Way Radio Questions & Answers
Check the buttons on the radio. One may be "jammed" especially the MON button. It would indicate receive all the time. Check for dirt around the button and case, it can surprise you what little can jam a button. I clean around the buttons with cotton swabs and alcohol. Be careful and do not use sharp objects to move the buttons back and forth, side to side, up and down. I suggest your fingers, or a dull letter opener or screwdriver, but little force. If the MON or other button does not release, you may need to take the case apart.
http://www.motorolasolutions.com/content/dam/msi/docs/business/products/two-way_radios_-_unlicensed/_documents/tlkr-t_series/static_files/t5_manual_eu.pdf
Motorola TLKR T5... | Answered on Sep 04, 2016
Check the sensitivity of you Radio and if it is very weak then change the wide filter.
Motorola TLKR T5... | Answered on Jul 11, 2016
The "MONITOR" is probably stuck on. You can go to
http://www.mods.dk/manual.php?brand=motorola and login (its free) and download the manual and look for how to turn off the "MONITOR" function.
Motorola TLKR T5... | Answered on May 11, 2015
Try to google or contact maker for
reprograming codes or buttons to hold down
or a web site to download it from an hook them
to computer an load. Sounds like a program
prob
Motorola TLKR T5... | Answered on Jun 01, 2014
wa de ptt toets?
Motorola TLKR T5... | Answered on Jan 05, 2014
Sounds like the speaker got wet. If there is an earphone socket, does that sound OK ? If so, the speaker is your problem and must be changed out.
Motorola TLKR T5... | Answered on Nov 06, 2013
i had them for 5 years.
and they were just great.
in 6 months the one after the other did the same thing.
motorola is trying to tell us that we have to buy a new pair.
they sould know that i will not buy motorola again
Motorola TLKR T5... | Answered on Jan 27, 2013
For this problem contact your mobile service provider.......
Motorola TLKR T5... | Answered on Sep 10, 2011
Try setting the radio back to a simple mode of operation. Shut off all special features such as the sub-code (interference eliminator code), VOX, room monitor, and call tones. Go to just one basic channel, such as channel one. Then check to see if the radios talk to one another. If not, check your battery packs, as it takes more energy to transmit than to receive. Swap battery packs and see if the problem moves to the other radio. And lastly, get a third radio involved to see if one of your radios is simply defective.
For your convenience here is a link to the user guide: http://www.gouldelectronics.co.uk/product-downloads/T5-20Manual-20EU.PDF
Best regards.
Motorola TLKR T5... | Answered on Aug 31, 2011
I would highly advised that you would need to contact your manufacturer for you to further assist you.
Motorola TLKR T5... | Answered on Aug 07, 2011
Check your programming. The frequency and code must be identical on the two radios. Here is a link to the user guide http://www.gouldelectronics.co.uk/product-downloads/T5-20Manual-20EU.PDF
The description you give is indiciative of the code being set differently between the two radios. For basic operation set the code to off (zero).
Best regards.
Motorola TLKR T5... | Answered on Feb 16, 2011
Hi.
Remove battery from both handsets to reset them ensure that batteries are fully charged. If problem persists, try removing roger beep. Press and hold the up arrow key while turning the
radio ON to turn on/off the roger beep.
Here a manual:
T5 Manual.book
Motorola TLKR T5... | Answered on Aug 29, 2010
Hold down the "SEL" button to unloch it and then search for the manual on http://www.radios-uk.com/manuals.htm
Motorola TLKR T5... | Answered on Dec 28, 2009
Motorola TLKR T5  Two Way Radio Logo
Popular Tags
29 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
tlk3 t3 motorola permanent static noise
  • Radio Communications
