20 Most Recent Sony Reader Pocket PRS-300 Questions & Answers
Depending on what the file type is you can always try another application to open up the book for example if it is a pdf format you can always try using adobe reader. However, I believe the issue here is that there is a page that might have been corrupted or unviewable depending on the situation you may want to consult whoever you got the book from in case you had purchased this book to see if you can maybe get another copy.
Sony Reader... | Answered on Jul 15, 2017
You have asked us to delete books from your tablet. We cannot do it unless we are holding the tablet. You will have to do it.
Sony Reader... | Answered on Dec 28, 2013
There are 2 ways. First being the easiest, since it can delete multiple books at one time. USB connect the PRS-300 to the PC. (It will read as a hard drive.) Go to the "database" folder, then to the "media" folder, then into the "books" folder. All your eBooks should show there, and you can choose which ones you want to delete and delete them all at once.
The second way only deletes 1 book at a time. Choose the book, then choose "Continue Reading" to open the book's menu page ("Options") on the reader. On the "Options" menu, choose "Utilities". When the "Utilities" menu comes up, press 2 for "Delete Book".
Sony Reader... | Answered on Jun 05, 2013
If you are using the PRS-300, then you need to get a PSP charger (AC-Adapter/wall plug) to charge it.
Sony Reader... | Answered on Jun 04, 2013
To charge a PRS-300, you need an AC-Adapter (wall plug) from a PSP console.
As for the syncing problem, you may need a new USB cord.
There's a small hole on the bottom used to reset the reader. I suggest you get an ink pen with a fine point or a toothpick or paper clip, and press in there to reset it.
I have had this problem with my PRS-300 before, and that usually fixes it. Sometimes, it erases all your books from the reader, though, but you can easily put them back on via USB.
This issue may be caused by the Data Execution Prevention feature in the Windows Vista operating system or if certain folders used by the Reader Library software are corrupt. Add the Reader Library to the Data Execution Prevention feature. To add the Reader Library software to Data Execution Prevention,
Please click here to get the steps.
Sony Reader... | Answered on Nov 18, 2012
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sony Reader... | Answered on Nov 08, 2012
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sony Reader... | Answered on Aug 08, 2012
please look clearly there will be a reset button to restart if there is no reset button then open it with the help of secrew and cut the connection of battery and after few second reconnect the bettery to to turn on but remember the connection should be same as before the cutting mean to and - to - terminals
Sony Reader... | Answered on Sep 09, 2011
Hi vicky1925!
There is no firmware update for PRS300, I checked on their website www.esupport.sony.com. Maybe sometinhg got corrupted on the internal memory. You can try to do a "Hard Reset" on the eReader. This will set the unit to factory settings and will delete all content:
1. Disconnect the Reader
2. Hit the Reset button at the bottom of the Reader
3. While the reader shows 'Opening Book...' press and hold the number '0' (Zero) and the 'Down Arrow' both at the same time until reset all appears
4. Once you do that you will get a confirmation saying that all content will be removed icon_e_sad.gif you just press number 5 to confirm
If this does not work, contact Sony for service options =(
GoodLuck!
eBookBoy
http://digialreader.freeforums.org
Sony Reader... | Answered on Jul 29, 2011
Hi pmteach4u!
ecause of e-ink technology, sometimes it may appear that the reader is frozen, you can try to reset the reader
1. Disconnect the Reader from the Computer
2. Hit the reset button for 3 seconds at the bottom of the unit with a paper clip
3. Slide the power switch, the screen will blink and will show "Opening Book". Allow the Reader to load.
If the issue still persist, follow the steps on this link:
http://digialreader.freeforums.org/solution-for-frozen-sony-reader-t10.html
GoodLuck!
eBookBoy
Sony Reader... | Answered on Jul 27, 2011
Hi vailzamorta!
You can try to do a "Soft Reset" on the Reader. Do not worry, this will not affect your ebooks =)
1. Disconnect the reader from the computer
2. Hit the Reset button at the bottom of the unit for 3 seconds with a paper clip
3. Slide the power switch at the top of the eReader
4. The screen will blink and show opening book.... allow the reader to load
Just in case here are some other steps to try in case this does not make any difference
GoodLuck!
eBookBoy
Sony Reader Pocket PRS-300 Logo
156 questions posted
Top Sony Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Computers & Internet
Most Popular Question
reader frozen message firmware
  • Computers & Internet
