20 Most Recent
Matsonic MS8147C+ (N82E16813184008) Motherboard Questions & Answers
Upgrade CPU on Matsonic MS8147C+
Unfortunately I think the Athlon XP is a 462 pin package and the MS8147C+ has a SocketA/Socket 462 socket for the CPU. The Athlon 64 3800+ is a 940 pin package and requires a AM2 socket, so this CPU will not physically fit.
1/19/2014 12:53:59 AM •
Matsonic...
Answered
on Jan 19, 2014
No sound
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
11/13/2010 12:05:34 AM •
Matsonic...
Answered
on Nov 13, 2010
Does this have a SATA connection for a SATA HDD
I cant find specs or a good big pic so I can see it, the sata jacks are similar in appearance to usb potrs, on the Motherboard they are usually clumped together (If there's more than one), If it doesn't have them you can get a PCI card with SATA potrs and put that in.
5/11/2009 10:52:12 PM •
Matsonic...
Answered
on May 11, 2009
Ms8157e on board video problems
You would need to do this from the BIOS. You would gain access to the BIOS during the first boot screen prior to Windows. It will either be "F12" or the "del" key most likely.
Once there, you'll most likely be looking fo something related to Integrated Peripherals and specifically onboard video adapter. You'd want to select some sort of disable option for this.
3/4/2009 12:42:22 AM •
Matsonic...
Answered
on Mar 04, 2009
