20 Most Recent
Haier HL42XR1 LCD TV Questions & Answers
How do I get television channels do I need a antenna without cable?
Yes, you will need an antenna to get live OTA TV. The Haier HL42XR1 has an ATSC (digital OTA) tuner and a NTSC (analog OTA) tuner. Your location and distance to the local transmitters will determine what type of antenna will be best. See
antennaweb.org or
tvfool.com and enter your address. TVfool.com gives a full list of all stations you may be able to receive depending on your antenna (indoor, outdoor, height, direction). If you share the signal from the antenna with another device, you may need an amplifier to maintain the signal strength. (Warning, when amplifiers fail, the signal can become worse than the unamplified signal. With digital TV, signals are either strong enough for the tuner to understand or a "no signal" message will appear.) I hope this helps. Cindy Wells
Code for haier
These are the setup codes for Haier: 0081 0216 0217 0157
10/26/2012 5:20:11 PM •
Haier HL...
Answered
on Oct 26, 2012
Am I suppose to put water into the Haier Standing Portable Air Conditioner?
Most air conditioners need water removed, not added. They act as dehumidifiers as they change the air temperature. What model air conditioner do you have? The Haier HPRD12XH5 has a blinking red LED with a triangle symbol to indicate the unit is flooded. Air conditioners can also fail if there is a coolant leak or the room is too cool. If the removed water freezes in the air conditioner, it can damage the fan and cause the motor to overheat.
The air cooling systems that need water added are "swamp coolers". That's the term I learned for the old-fashioned fan + ice/water cooling systems that work well in low-humidity environments. They'll make the area feel hotter in high humidity conditions.
I hope this helps. Please add a comment with the model of your unit for further information.
