look at this video
you need to shoot a video or take an image using your cellphone
the ccd sensor is sensitive to the transmitter IR Led at the Remote
and can show you whether it emittes photons and works
Working with Plasma displays is a skilled work indeed. Anyway, if you're sound in electronics, you can understand the details well. Check this link. It has details about the faults that occur to a Plasma display. Illustrations or screens shots are given. Pull
up older posts there, either by its left side bar, or see it in Timslide
option. http://electronicshelponline.blogspot.com/
This is a plasma tv not lcd. The pop mostlikely was a part on the y main board. IF the y-main voltage shifts the set will have red sparkels.
EBR55360701 All tech depot . com $65.00
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
It can't be done. The DVD remote will be single frequency for that device only and the LG remote for that LG Blu Ray (or series) only. Companies don't make cross-control between makers easy. The only exception is cable and satellite boxes to allow their remote to also control the television.
If you have lost a remote or it doesn't work, this is the answer
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
