20 Most Recent Samsung PN58B540 58 in. Plasma HDTV Questions & Answers
ensure TV's 'mute' is not on. use buttons on TV to adjust volume up and down. if not working properly, you may have a volume adjustment on your cable modem which needs to be turned up to maximum. if sound works, all is well. if sound still not acceptable your TV needs repair.
if TV buttons adjust volume OK, and your remote for TV does not properly adjust volume, try fresh batteries. if
remote still not working properly, you can buy replacement on EBay or try a genaric remote from a dollar store. also, i may have an extra remote for you.
Samsung PN58B540... | Answered on Mar 03, 2018
Unplug it, take the back off and have a look. If something was popping, im sure you will find which board blew out. Make sure you get the full model and serial number so that when you order a replacement, you get the right one.
Samsung PN58B540... | Answered on Sep 29, 2015
hi this fault could be one of the buffer boards, there's ic chips on these board usually burn out causing the ysus board to fail i'd look for tech in your area hope it helps
regards
shaun
Samsung PN58B540... | Answered on Jan 26, 2014
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Samsung PN58B540... | Answered on Aug 23, 2012
Just visit this site for more details.
Type in this site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search or press Enter. It is an electronic equipments service help site.
Note the position of hyphen in between words in site name. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can locate this site name, either at the bottom part of first search page, or at the top of second page.
Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price and more.
Samsung PN58B540... | Answered on Jun 05, 2012
HI,
There is some overheating problem in your tv. In all plasma tvs the will be cooling fans to maintain the teparature level. In some models there will be two fans. If the fan didn't run at the correct RPM the teparature will incrase and this will sensed by the thermal sensors and shuts of the tv preventing from further damages. Chek the fans inside you tv. If it is availabel near by you then try to replace it. If the fan is stuck then try to iol the same. To know how to oil the dc fan watch the following video.
ok
Samsung PN58B540... | Answered on Jul 22, 2011
if it is Brand new I think you should return it ASAP
Samsung PN58B540... | Answered on Mar 31, 2010
check the display strip. un plug it and fix it
Samsung PN... | Answered on May 14, 2019
the capacitors seem to have gone bad if they have like a black dot on them it is a sign they have actually blown they can be replaced by placing new ones on but it would be better if the board was replaced (unless you wish to replace those capacitors please please do be careful in doing so they hold enough charge to give you a bad zap even kill if one isnt careful)
Samsung PN... | Answered on Jan 05, 2017
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
Samsung PN... | Answered on Jun 30, 2016
www.samsung.com/us/support
Samsung PN... | Answered on Feb 01, 2015
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Samsung PN... | Answered on Sep 13, 2014
Samsung PN58B540 58 in. Plasma HDTV Logo
23 questions posted
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
View Most Popular
PN Samsung
  • PN Samsung
Most Popular Question
no picture but sounds
  • Televison & Video
