20 Most Recent Dynex DX-L42-10A 42 in. LCD TV Questions & Answers
2answers
Dynex Flat Screen 22" w/DVD
When the picture goes out, try to open and access the TVs menu using the Dynex remote. if the menu fails to open up you can bet there is a problem with the backlight on the TV. Letting the TV rest and then it working again indicates heat as the source of the problem. Check to see if your still in your 1yr warranty or if you have a protection plan at best buy, the TV needs help.
If the Menu were to still open, you can blame your cable/satellite set top box.
10/11/2020 10:00:51 PM • Dynex DX-L42-10A... • Answered on Oct 11, 2020
2answers
I have static sound when tv is on
If it is HD make sure that all the chords are put in the right spot. Make sure that the right colors are in the right spots as well.
5/20/2020 11:19:49 PM • Dynex DX-L42-10A... • Answered on May 20, 2020
We have the stereo hooked up to the dynex 42
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
11/19/2016 8:55:24 AM • Dynex DX-L42-10A... • Answered on Nov 19, 2016
Dynex dx-40L261A12 won't turn on. Red power light
In this case, the symptoms you describe is a faulty inverter board. The TV will or should flash "PLEASE WAIT" and then you have a black screen no audio. Find Shop Jimmy on line. Enter your TV model number. You will find an inverter board for $24.95 plus $9.50 shipping. When you remove the back cover of the TV, look to the left. You will see a long vertical board...this is what you will replace. Thanks for asking, Matt of Martins TV Repair.
11/4/2016 12:27:39 AM • Dynex DX-L42-10A... • Answered on Nov 04, 2016
Check t-con board
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ ...
8/24/2016 2:19:46 PM • Dynex DX-L42-10A... • Answered on Aug 24, 2016
What causes blue streaking on screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
2/23/2016 3:32:39 PM • Dynex DX-L42-10A... • Answered on Feb 23, 2016
How to replace antenna input mudule
It can be replaced. Contact any service technician. http://electronicshelponline.blogspot.com/
1/11/2016 10:35:09 AM • Dynex DX-L42-10A... • Answered on Jan 11, 2016
I don't have a remote and need to know how to set the input manually
Hi, Check the picture bellow. Find out the switches in you tv. You can change the input by pressing input button. in some models if you press repeatedly the input button the input will also change . in others you have to press the iput button once and select the desired input by pressing channel up/down or volume up/down buttons. www.electro-medical.blogspot.com 25848110-1kzkugmxiwn42xx5hfeyidyd-3-0.jpg
9/3/2015 3:29:02 PM • Dynex DX-L42-10A... • Answered on Sep 03, 2015
2answers
DYNEX TV NO SOUND
Hello, there are so many reasons why your TV won't bring out sound. You need to troubleshoot first, in order to get to the root of the problem, before a solution can be proffered. First, connect a DVD player to the TV, observe if there is going to be sound. If there is still no sound after connecting the DVD player to the TV, proceed to the next step. "The reason why I asked you to connect a DVD player to the TV is to confirm if the problem is simply not from the audio cord connected to the TV." Second, get an headset, connect it to the earphone jack of the TV and observe if there is going to be sound. If there is no sound, then it is glaring now that your TV is having a defective sound card/IC that's why it is not bring out any sound. (Note that connecting an headset to your TV is optional because not all TV's has a space for headset). "The reason why I asked you to connect an headset to the TV is to also confirm if problem is not from the TV speaker. Though TV speaker problems are rare but sometimes, the TV speaker might be defective or the speaker wires may have loosed contact or cut into two, due to one reason or the other. But if the headset doesn't bring out any sound from the TV, then it is not so." If none of the above seems not to be the cause of the problem, then the above troubleshooting has confirmed that the TV has got a defective sound card/ic. The sound IC/card of the TV has to be replaced for the TV to bring out sound again. To be honest with you, replacing or fixing the sound card/ic of your TV requires the ability or experience to do so. Now, if you are convinced you can fix or replace this yourself, please reply so that i can help you further. And make sure you troubleshoot first, before getting back to me. Regards.
4/8/2015 11:19:16 AM • Dynex DX-L42-10A... • Answered on Apr 08, 2015
How can I fix the picture color problem on my Dynex TV?
hi, thanks for contact me : seems that your TV have a bad T-CON board, you have to take it apart and check for the exact part number on the board, because those sets have different version of those boards. to give u an idea after you take it apart look at the top of the screen for a part like this : http://tvrepairtips.org/files/styles/tvrepairtips-text-overlay/public/field/product/55.42T06.C16.JPG after find the correct part number get back to me to address you in the right way
3/4/2015 8:02:02 PM • Dynex DX-L42-10A... • Answered on Mar 04, 2015
I have static when my tv comes on
normal in most LCD and tube tvs. nothing to worry.
12/18/2014 10:53:00 AM • Dynex DX-L42-10A... • Answered on Dec 18, 2014
2answers
How do I check capacitors?
HI, instead get around testing our recommendation is to get the another power supply instead, that will be easy to just plug and play here is your replacement : http://www.bostonrecycling.net/power-supply-board-main/1022-dynex-dx-l42-10a-power-supply-6kt0032012.html and the shipping its FREE
10/9/2014 6:31:16 PM • Dynex DX-L42-10A... • Answered on Oct 09, 2014
How can I stop my tv from freezing during use
Digital processor board fault. Contact any service technician. Electro help
10/1/2014 12:28:39 PM • Dynex DX-L42-10A... • Answered on Oct 01, 2014
How do I get the high def side my Dynex 40in LCD tv to work
TRY connecting thru your composite connections to see if that works, also try a new HDMI cable. if it works thru composite & not the HDMI input then you have either a source issue or a bad MAIN/IO PCB
9/23/2014 10:45:05 PM • Dynex DX-L42-10A... • Answered on Sep 23, 2014
My Dynex 42 inch tv model #DX-40L261A12REV.A it comes on tells you please wait then shuts off. Is there a reset on it or is there something else I can do?
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
9/14/2014 3:47:40 PM • Dynex DX-L42-10A... • Answered on Sep 14, 2014
0answers
Dynex DX-L42-10A 42 in. LCD TV Logo
172 questions posted
Top Dynex Televison & Video Experts
Jaime Hernandez
Jesse Walters
Jesse Walters
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Dynex Televison & Video
Most Popular Question
dynex dx 40l261a12 turn red power
  • Televison & Video
