20 Most Recent
Matsonic 8328E (MS8328E) Motherboard Questions & Answers
Manual and Drivers required
Thank you for contacting FixYa I am Pandu I will help you to download the motherboard drivers.
Please open this website and you will find all drivers related to your motherboard http://www.driverworld.dk/search/Matsonic/
My pc has power but the motherboard does not beep
Try pulling your memory sticks and turn on unit is there any beeps ?
if not the pull all pci cards, ie modems and video, optical drives, anything but main hard drive and turn on see if you get beeps then ONE AT A TIME replace cards till you find which one is bad \
That is if it is a hardware problem
Please tell audio drivers
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Matsonic MS8328E user manual
Here is the pin out for USB connector.
1 VCC 2 VCC
3 USB0 4 USB1
5 USB0+ 6 USB1+
7 GND 8 GND
9 Key(no pin) 10 USBOC
Installation drivers
http://www.matsonic.com/drivers/view.php?modelID=MS8328E
copy paste th above line into address bar of your web browser go to site it lists bios lan sound vga driver for your board
please post rating etc
In need of drivers
Audio drivers are located
here, your motherboard uses the Realtek Ac'97 audio chipset.
As for video drivers, they are available for download
here, your mainboard model number is listed about halfway down. You just need the free registration to gain access to the video driver, you don't need to pay.
VGA Drivers
Use everest home to get the details of the vga
http://www.majorgeeks.com/download4181.htmlWhen you got the program go to devices -> windows devices
find your display adapter which doesn't have driver and see what kind of details it gives you
You can also do a report with the report button
Vt8366 8233
http://ez93.com/dl/vt8366-driver.html
5/19/2014 5:03:06 PM •
Matsonic...
Answered
on May 19, 2014
