20 Most Recent
Jwin JX-MP144 MP3 Player Questions & Answers
How to turn it on
To turn this player on, press and hold the play/pause button [}II]. Hope this solution helps.
Have had this JWIN model JK-777 turntable/am-fm/cassette/cd player unit. It won't power on now. Checked the outlet, no problems there. Does this unit have a fuse?
1. It's more likely the problem is a broken power cord or dirty power switch. If you've been in the habit of yanking the cord to unplug the unit instead of pulling directly on the plug, or somebody tripped over the cord, the power cord is probably broken right at the plug.
2. Changing a blown fuse without finding and repairing the fault that blew the fuse will only give you another blown fuse. It's not like the old farmhouse with too many things plugged in on the same fuse... A blown fuse in audio equipment is usually the result of a shorted speaker driver transistor. The transistors come in pairs; if one is bad the other has been overloaded and should be replaced also. That's a job for an electronic technician.
My mp3 wont play songs that i put
My jwin jx-mp101blk quit when I deleted the folders in it to make room for saving stuff. It still works as a memory stick, but won't play. What are the needed files?
How to i format music to mp3
You need to use a video converter to deal with the format problem.Go and have a try for this one which I have used for long,it will help you easily convert the music to Mp3.here is the link for this good
video converter.
