20 Most Recent
Anycom CC3103 PAROS-10 MINI BT 2.0 HEADSET 6HR TALK ONLY 3 OZ ESCO TECHNOLOGY Bluetooth Questions & Answers
When turn to connect to
Basically the default code for most blue-tooth headsets is either 12345 or 00000. Try these codes and even refer the manual as you have to pair the headset with your phone before you can use it.
Lost my book need passcode
Well you can use 0000 it's the default passcode of your bluetooth headset. Most of the bluetooth headset use 0000 as default passcode.
Good Luck!!
Thanks for using FixYa!!
How to change the battery in my Anycom HCC-250
A rechargable Li-Polymer battery should be included with a charger for it when you bought it.
Note:
It is recommended to charge your Car-Kit when it is not in use.
Please note that "inserting" charger will cause a device reset. However, when the Car-Kit is in charging (the charger has been inserted), the Car-Kit is in normal
operation
