20 Most Recent Kodak EasyShare C140 Digital Camera Questions & Answers
Was the card used for any other purpose, as in MP3 audio files? Try formatting it using the setup menu. This will erase EVERYTHING on the card.
Kodak EasyShare... | Answered on May 07, 2018
Kodak drivers can be found here: Driver Update Software for XP Vista 7 8 Have a nice day.
Peter
Kodak EasyShare... | Answered on Jan 05, 2015
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Kodak EasyShare... | Answered on Sep 04, 2014
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Kodak EasyShare... | Answered on Jul 27, 2014
a quick and very simple Google search mentions that 32GB will work and class 4 or higher...... but why you'd want to put that much memory (or more) into a battery eater i don't know..... forgive my sarcasm but i was curious of how hard you actually tried looking, and i deduce you didn't try at all!!!
Kodak EasyShare... | Answered on May 25, 2014
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Kodak EasyShare... | Answered on Apr 20, 2014
Make sure batteries are not dead or too old and/or your display is not broken.
Kodak EasyShare... | Answered on Jan 02, 2014
Hello.
Change the mode - photos
Turn off the flash.
If the camera does not eliminate, the problem may be in the mechanism of focus.
If the camera is shooting flash off - the flash is faulty.
Kodak EasyShare... | Answered on Oct 28, 2013
You don't need any software in order to use your camera.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
If you really want the Kodak software, you may download it from http://support.en.kodak.com/app/home/src/gosupport/selected/true
Kodak EasyShare... | Answered on Oct 04, 2013
Go to the camera's Menu setting, scroll down to format internal memory.
Note You need to copy your photos to the computer before you format the memory because when you format the memory the existing photos will be wiped off the internal memory.
Kodak EasyShare... | Answered on May 13, 2013
You don't need any special software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Kodak EasyShare... | Answered on Feb 02, 2013
Serious internal problem. needs to go to shop, common with this model.
Kodak EasyShare... | Answered on Jan 24, 2013
Hello, Sounds like bad news, this is usually due to a defective CCD unit. Very costly to have repaired. Many Kodak models had problems with faulty CCD units.
Best of Luck, Russell
You don't need a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Kodak EasyShare... | Answered on Sep 09, 2012
Kodak EasyShare C140 Digital Camera Logo
72 questions posted
Top Kodak Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
kodak c1450 driver
  • Cameras
