20 Most Recent Olympus FE-46 Digital Camera Questions & Answers
My Olympus Fe-46 digital camera taking blurry pictures and buzzing when I turn it off?
this is a common problem with htc m7 & m8 they use a focus motor and get damage from motorcycle vibration or high shocks. i had the same problem on my m7 and m8, i took the phone to the supplier and i got new one instead. now am using different phone when riding
10/27/2017 1:03:17 PM • Olympus FE-46... • Answered on Oct 27, 2017
0answers
Sound video mode
no microphone on the camera
12/23/2013 3:25:47 PM • Olympus FE-46... • Answered on Dec 23, 2013
Turn on sound on FE46
no microphone to record sound was ever installed on this model
12/23/2013 3:25:27 PM • Olympus FE-46... • Answered on Dec 23, 2013
Will not connect to the computer
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto and Windows Photo Gallery.
1/25/2012 7:16:47 PM • Olympus FE-46... • Answered on Jan 25, 2012
What can i use as a usb plug for my olympus fe-46 camera i lost my original....
Consider a card reader, if your computer doesn't have one built-in.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto and Windows Photo Gallery.
1/25/2012 7:15:41 PM • Olympus FE-46... • Answered on Jan 25, 2012
My olympus fe-46 won't connect to my pc
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
1/24/2012 7:20:24 PM • Olympus FE-46... • Answered on Jan 24, 2012
Whenever I plug my olympus
Hi,Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.DigitalCamera Manuals, Drivers, Downloads, and SupportHow to easilydownload Pictures from Digital Cameraheatman101
8/4/2011 1:07:59 AM • Olympus FE-46... • Answered on Aug 04, 2011
Want to know the type
The FE-46 doesn't use SD cards. It uses xD cards or, with the included adapter, microSD cards.
7/31/2011 7:28:08 AM • Olympus FE-46... • Answered on Jul 31, 2011
What type/size memory card does it use? I have
It use micro SD card or micro SDHC. You can use also Transflash (TF) with SD adapter.
Please don't use other cards. Be carefully while inserted the card, do it by right orientation.
7/31/2011 4:25:34 AM • Olympus FE-46... • Answered on Jul 31, 2011
Is it possible to charge my olympus fe-46 from my
In a convoluted way. The FE-46 uses standard AA batteries. You may use either disposable alkaline or lithium batteries, or rechargeables. If you use rechargeables then you must charge them outside the camera. There are chargers that run from a computer USB port, and there are even AA batteries that plug into a USB port. However, you canNOT charge the batteries by connecting your camera to your computer.
7/29/2011 5:14:03 PM • Olympus FE-46... • Answered on Jul 29, 2011
My FE-46 olympus camera is
Try formatting the card while it is in the camera
7/18/2011 1:54:48 AM • Olympus FE-46... • Answered on Jul 18, 2011
0answers
The lens won't come out
Hi.
This error indicate that focusing ring got stuck or jammed. What you can try to do is spray some compressed AIR into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
7/4/2011 9:12:52 PM • Olympus FE-46... • Answered on Jul 04, 2011
Fe-46 pc connection problems, unkonw
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
6/13/2011 6:54:05 PM • Olympus FE-46... • Answered on Jun 13, 2011
The camera won't turn on.
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
5/19/2011 2:22:28 AM • Olympus FE-46... • Answered on May 19, 2011
Olympus FE-46 Digital Camera Logo
55 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
David Shaub
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
FE Olympus
  • FE Olympus
Most Popular Question
usb driver
  • Cameras
