20 Most Recent
Matsonic MS9327E (MS9327E+(USB)) Motherboard Questions & Answers
Windows xp Free when scan
if you want to check and clean up your hard drives and operating systems
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
hope this helps
I need MS9327E-USB - VGA
http://www.givemefile.net/drivers/mainboards/msi/file/13241.html
This motherboard may not be windows 7 compatible. Try that driver though. It could possibly work. Let me know if it did.
Ms9327e mb built in network
i think the problem is from your modem, check your modem setting, or this because your router is have some limit setting, check it
I am in the process of installing a second hard
The boot order is messed up - the network is the first instead of the last so the pc tries to load the OS from it first hen that fails the next device is accessed - in your case the hdd.
Go into the BIOS and fix that. While you're there make sure the SMART is activated.
I want to max out
If this motherboard is still in your tower then visit Crucial.com, there you can use their System Scanner Tool and it will tell you whats is compatible to install.
Lost multimedia drivers dont have disk
If u know your multimedia device name & manufacturer name &brand name. U just open your my computer window, right button click the blank space, after properties, hardware, device manager open & u found your multimedia option symbol is ( ! ) type. Select right button & update the driver on the net. Or, u open your Google web site & write the multimedia device name (Enter). After u found your device driver details.
Computer freezes
make sure your CPU fan is functioning correctly, this happens generally when the CPU is overheating due to fan problems or stoppage. If the fan is ok, and the CPU is not overheating, try a different memory, one of will work.
helpful ? if not reply and i'll give you other hints
Will the ms9327e + (usb) support a SATA drive?
well it depends on what board you have.
your best bet is to look on the motherboard.
the SATA connection looks almost identical to the connection on the harddrive, so you can use that for reference.
on the harddrive you will see 2 plugs. the smaller one plugs into the motherboard and the larger one is power.
for power, power adaptors are made to convert the standard 4 pin connector to a SATA one.
