20 Most Recent Matsonic MS9317E Motherboard Questions & Answers
0answers
I cannot get internet.th pc
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers the driver might be on the disc supplied by your ISP internet service provider or the motherboard disc hope this helps or you could download one cnetdownload.com on the homepage you will see a search bar type in the ethernet controller freeware you want/need Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html hope this helps
6/25/2011 7:52:34 AM • Matsonic MS9317E... • Answered on Jun 25, 2011
Sound card
if your computer came with a motherboard disc the sound drivers could be on it you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling a yellow? question mark means you need to install/update driver to do this right click to install driver also click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps don
2/16/2011 2:21:43 AM • Matsonic MS9317E... • Answered on Feb 16, 2011
Is this a Pentium 3?
Nope. Its a Socket 478 for Intel(R) Pentium(R) 4
10/12/2010 3:33:12 PM • Matsonic MS9317E... • Answered on Oct 12, 2010
My mother board is ms9317e
You cannot run both sound card simultaneously. Bcoz your OS is not support this feature. If you want to run the motherboard sound card you need to select it from control panel > Multimedia(sound and audio devices) > Audio > select your sound card for playback and recording
9/25/2010 10:31:14 AM • Matsonic MS9317E... • Answered on Sep 25, 2010
Both two parallel ports do not work together
You will have make one a master adn one a slve because of the adresses and of course you could change those but its to hard to tel you how. Go into setup and configure the setup or if on hard drves last on the cable is master other is slave and the you jumper your hard drive for csl (cable select)mMater or slave by cabling or master adn then slave look at your jumpers on your hard drive
1/18/2010 7:48:47 AM • Matsonic MS9317E... • Answered on Jan 18, 2010
I have a mb ms8308ep and when i push the power
a single beep means that everything is fine
multiple beeps suggest that there is something worng either with the motherboard or with the devices on the motherboard
8 beeps mean that the video card is faulty
change your video card
9/29/2009 6:24:06 PM • Matsonic MS9317E... • Answered on Sep 29, 2009
When i start to play game in my computer.my
You may have a short in your computer wiring or some sort. Or just try to update your graphics card driver.
6/5/2009 11:17:28 AM • Matsonic MS9317E... • Answered on Jun 05, 2009
Matsonic MS9317E+ 1.0 this is my motherboard but
Hey priyanka this is the solution1 restart the pc and hit bios menu button whter its DEL button or F2 u'll see front audio panel which could be HD Audio or realtek AC 97.if u can find them all then change it from HD audio to AC 97.2 resatrt d pc and open windows uninstall the realtek audio driver packeg which you can find in control panel then again install the sound driver packeg after restarting the PC.It'll work.and if you find some prblems then you can contact me any time.
4/23/2009 6:42:25 AM • Matsonic MS9317E... • Answered on Apr 23, 2009
2answers
Matsonic 9317E(+)
Since Matsonic doesn't seem to be around anymore you will probably have to download the drivers from the chipset (SIS 651) manufacturer's website HERE
Just click on Download at the top of the page to get a list of available drivers.
Here's your boards specifications
3/17/2009 7:10:05 PM • Matsonic MS9317E... • Answered on Mar 17, 2009
Usb1
Get an USB 2.0 card..sometimes the motherboards usb doesn't work
Go here to get a good one this one will do usb and firewire..
Good luck
1/19/2009 4:44:52 AM • Matsonic MS9317E... • Answered on Jan 19, 2009
MS9317e+ manual
CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
400/533 MHz FSB Chipset SIS 651 + 961 MS9317E+
SIS 651 + 962 MS9317E+(USB)
MuTIOL® Delivering 533MB/s Bandwidth Memory Supports two 184-pin DDR DIMM maximum size up to 2GB
Supports two 168-pin SDRAM DIMM maximum size up to 2GB
Support DIMMs of DDR333/DDR266/PC133 CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
Support DIMMs of DDR333/DDR266/PC133manual for this board is no longer available but above is your mobo info
11/1/2008 8:35:21 PM • Matsonic MS9317E... • Answered on Nov 01, 2008
Sound on the computer
click Start > Run > type devmgmt.msc > click OK > if you see that you have Sound device, check if it's working properly. If it isn't uninstall it from device manager and then restart computer. hopefully windows will recignize the hardware and reinstall the drivers for you automatically.
7/8/2008 9:49:25 PM • Matsonic MS9317E... • Answered on Jul 08, 2008
Ms9317e does not boot
you better go to last resource directly:
1. disassemble the system completely and take the mother out the case... Give it a perfect cleaning.
2. place the mother over a wood table or something like that (mother without anything but the cpu).
NOTE: if you are running onboardvideo do not connect external video board... if you are using external videoboard and do not have onboard video, you might have problems on the board... so you could need another one).
3. just connect RAM and power supply (the power supply must be out of case, placed over the table too and well connected to mother and to power line.
4. power on the system by jumping the pins on the motherboard... you can find them under the identification front pannel or something like that deppending on the model... just the pins that normally you attach to the cables that leads to the buttons on the front of the case. (use a screwdriver and do not touch anything on the motherboard with your hand if its connected to powerline).
then, and after trying vga adapter if you have one and trying rams one by one in different socks... you will know that if the system never boots up, you have hardware problems, either on mother, ram and less probably, power supply or very rarely cpu...
g luck, in this cases... better go live chat...
3/22/2008 12:42:24 AM • Matsonic MS9317E... • Answered on Mar 22, 2008
I have a matsonic ms9377c+ motherboard that will not accept 2-1gig memory modules. They are crucial memory and the right type. Put one in and it works, put two in and it wont even fire up. switched bo
You said you tried them both one at a time....did you try one at a time trying both sockets? Sometimes a defective memory slot will cause the symptom you describe. Also, in rare cases, memory modules of the same type and speed may not operate together.
12/19/2014 4:42:54 AM • Matsonic... • Answered on Dec 19, 2014
Vt8366 8233
http://ez93.com/dl/vt8366-driver.html
5/19/2014 5:03:06 PM • Matsonic... • Answered on May 19, 2014
0answers
Rom ms 7336
Be the first to answer 5/15/2014 2:22:35 PM • Matsonic... • Posted on May 15, 2014Be the first to answer
Matsonic ms8308ep (266) bios update .rom file
here you go http://www.wimsbios.com/forum/where-can-find-motherboard-manual-f34/latest-bios-and-manual-for-the-matsonic-ms8308ep-266-t10996.html
5/14/2014 11:03:13 PM • Matsonic... • Answered on May 14, 2014
Matsonic MS9317E Motherboard Logo
17 questions posted
Top Matsonic Computers & Internet Experts
 Mike M
Mike M
Tom Chichester
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Matsonic Computers & Internet
Most Popular Question
mb ms8308ep when push power
  • Computers & Internet
