20 Most Recent Matsonic MS8137C Motherboard Questions & Answers
2answers
Mother board post
Yes, if replacing the cmos battery does not solve it, then maybe the power supply also is faulty.
Thanks,
Lolita
10/6/2018 7:35:20 AM • Matsonic MS8137C... • Answered on Oct 06, 2018
What power supply connector will work with the ms8137c motherboard (aka, 20 + 4 pin)
Ahem, you just posted 20 + 4-pin. That means it can be a 20-pin ATX main power cable, OR a 24-pin ATX main power cable. Most power supply's now have a 20 + 4-pin power cable. Use the 20-pin connector, or add the additional 4-pin connector, to make a 24-pin ATX main power cable. Example.http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4In direct answer to your question, however, it uses a 20-pin ATX main power cable.For additional questions post in a Comment.Regards,joecoolvette
6/18/2012 12:22:03 AM • Matsonic MS8137C... • Answered on Jun 18, 2012
MS8137C-when installing win xp starts
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ? one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure your computer ram modules are securely seated with no dust in sockets hope this helps
9/5/2011 7:50:41 PM • Matsonic MS8137C... • Answered on Sep 05, 2011
I own a VIA Matsonic
Try resetting your BIOS or CMOS. If it does not work you may need to flash the firmware of your BIOS.
4/30/2011 12:25:06 PM • Matsonic MS8137C... • Answered on Apr 30, 2011
Driver ms8137c maiboard
You can get files for this motherboard from http://www.desktop-computers.ws/view.php?modelID=MS8137C
3/7/2011 1:09:28 PM • Matsonic MS8137C... • Answered on Mar 07, 2011
0answers
When I turn all it does is beep have a steady red
Your issue sounds as though it is the power supply that is in need of replacement.
If there is a steady red light on then the PC unit is not getting it -12/+12/-5/+5 voltage at the connectors also you may have inadvertently switched the cable connections that is pin 1 of the cables is not getting the voltage it needs to the device.
The red line on the cable or the (+) is the supply pin to that device.
1. check the power supply and all the connectors.
2. clean all dust from the inside of the the connector and around the CPU
3.check the CMOS battery (looks like a new quarter) should show 3.7 volts with a volt meter. If readings are below this you need replacement.
I hope this helps. Have a great day!
10/5/2010 8:56:19 PM • Matsonic MS8137C... • Answered on Oct 05, 2010
I hav a new operating
try this link below:<br /><a href="http://www.driverfiles.net/Bios/Matsonic/ms8137C/download/page,sh,10891,103,6,.html">http://www.driverfiles.net/Bios/Matsonic/ms8137C/download/page,sh,10891,103,6,.html</a><br /><br />and this link to:<br /><br /><a href="http://www.bestfreedriver.com/matsonic-ms8137c-driver3481zip.html">http://www.bestfreedriver.com/matsonic-ms8137c-driver3481zip.html</a><br /><br />
8/30/2010 11:44:01 AM • Matsonic MS8137C... • Answered on Aug 30, 2010
I NEED DRIVERS MOTHERBOARD
ok ap apni i.d bhaij do main snd kar du ga
8/16/2010 9:11:52 AM • Matsonic MS8137C... • Answered on Aug 16, 2010
I formated my system the sound is not working i
Did you try the manufacturer's website?
Another option is to try a driver finder program, which can provide compatible drivers from other sources as well.
7/7/2010 9:18:58 PM • Matsonic MS8137C... • Answered on Jul 07, 2010
I have matsonic ms 9097c desktop i try windows xp but its hang up
have u got xp cd ?? if u have put the cd to ur rom n restart ur pc n boot ur pc wit cd so u wil get the installing manu
5/22/2010 4:17:30 AM • Matsonic MS8137C... • Answered on May 22, 2010
Hello ,
It sounds like the system is set to "auto" at the moment, OR the memory speed will not support the 133mhz fsb speed, check the RAM and see what the speed rating is. Leave the CPU multiplier alone, that may well damage the cpu.
4/1/2010 7:34:33 PM • Matsonic MS8137C... • Answered on Apr 01, 2010
I have motherboard ms8137c with cpu 1.6 ghz but it
All Athlons were until a few months ago named on a power rating, not actual CPU speed rating. Since you didn't tell me the exact type of your processor i believe that it's the actual , normal speed of your CPU. But if it isn't then it's underclocked. To verify that go in the BIOS and see if the FSB is the correct value - 133MHz - sometimes it's at the default value of 100MHz. This can be changed from 2 locations:
1 - the JP4 jumper on the motherboard - 2-3 corresponds to 133MHz (of course you should change it only with the pc is disconnected from the mains)
2 - in BIOS go to Frequency/Voltage Control - CPU Host Clock and set it to 133.
3/24/2010 8:48:07 PM • Matsonic MS8137C... • Answered on Mar 24, 2010
2answers
What max large hard disk support Matsonic MS8137c?
unlimited really the biggest harddrive that is out knw is about 2 terrabites if you have a Sata connector and if you have a IDE ribbon connector then its something close to that
1/22/2010 5:55:12 PM • Matsonic MS8137C... • Answered on Jan 22, 2010
Matsonic MS8137C Motherboard Logo
50 questions posted
Top Matsonic Computers & Internet Experts
 Mike M
Mike M
Tom Chichester
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Matsonic Computers & Internet
Most Popular Question
highest video card use
  • Computers & Internet
