20 Most Recent HP PHOTOSMART PLUS B209A All-In-One Printer Questions & Answers
Remove printhead and let it sit in a window cleaning solution and warm water mix 50/50. See video on how to remove printhead:
HP PHOTOSMART... | Answered on Feb 04, 2019
Your printer ink cartridges may be dry or empty and printhead may also be dry. Try the fix in this video and order some cheap ink cartridges off ebay. They always work for me. Example link below:
https://www.ebay.com/itm/382706888626
Couple things: Look inside a printer with flashlight and make sure there is nothing in the way. Remove printhead and see if error goes away. See this video where printer has similar code and is fixed:
First try removing the printhead and cleaning it manually by soaking in a cleaning solution(50% windex or similar and 50% hot water). ALso the ink cartridges amy be dry even if the ink level shows normal level. Get a set on ebay for a very low cost and clean the printhead and you should not have a problem with printing at all.
Link to one of ebay listings: for USA:
For UK:
https://www.ebay.co.uk/itm/262487581895
It could be a bad printhead or just some ink got on the electronics contact part of it. Check out the video to resolve this issue:
Try this solution:
You can get a fairly cheap ink cartridge on ebay. Link below.
https://www.ebay.com/itm/232769315883
Also, try cleaning the printhead manually by taking it out and soaking the bottom of printhead in a window cleaning solution:
you have to take that orange piece off of every cartridge
HP PHOTOSMART... | Answered on May 10, 2018
using windows explorer, go into windows/system/spool/printers and erase contents in last item
HP PHOTOSMART... | Answered on Sep 14, 2017
Does your printer have a CD disk to install it on your computer. Go into My Computer and delete or remove everything that is associated with that printer then reinstall using your disk. That will reset it back to factory installation.
HP PHOTOSMART... | Answered on Dec 17, 2016
There is dust & ink build up on the printer head. Take it apart. Wipe it off by hand with print head cleaner & lint free cloth.
HP PHOTOSMART... | Answered on Aug 25, 2015
Hi, do note that even if you are printing in black, the printer requires that you have installed functioning cyan (blueish), magenta (reddish) and yellow cartridges as well.
HP PHOTOSMART... | Answered on Feb 10, 2015
Every time I had this problem it was the printer head. Try removing the cartridges, then the printer head. Be sure the head is seated firmly. Try printing again. The printer head expires long before it's suppose to so don't be surprised if this is the problem.
HP PHOTOSMART... | Answered on Sep 25, 2014
HI,
we are provides printer support services read more help... HP Printer Support
Thanks,
HP PHOTOSMART... | Answered on Aug 08, 2014
HP PHOTOSMART PLUS B209A All-In-One Printer Logo
225 questions posted
Ekse
efs_perpends
efs_perpends
View Most Popular
PhotoSmart HP
  • PhotoSmart HP
Most Popular Question
hp photosmart plus b209 printer
  • Office Equipment & Supplies
