20 Most Recent Ricoh Aficio SP C820DN Laser Printer Questions & Answers
Hi, I'd be glad to help you.
SC 553: Pressure roller fusing lamp over heat
The detected pressure roller temperature stays at 200°C or more for five seconds.
It could be:
• Defective PSU (power supply unit)
• Defective BCU (The BCU generates the FGATE signal based on the registration sensor ON timing).
Last time I had this error (over a year ago) on this model, it was the PSU.
Best of Luck
Ricoh Aficio SP... | Answered on Aug 10, 2018
No issues i share a informative links please visit and read it.
Read more help... How to fix printer paper jam andHP Printer Support
Thanks,
Ricoh Aficio SP... | Answered on Feb 24, 2017
it looks like the Cyan Unit is not set correctly, so you need to open the front door, in the area behind the front door up you will see the toner bottles under the bottles it has a cream-white plate, you will see in the middle of the plate one handle - leveler which is blocked with a plastic piece, which have a ***** in the middle remove the ***** than remove the plastic piece, after that pull the handle - leveler up to be set from horizontal position into 45 degrees angle upwards. After that in the upper right corner of the plate you will see another handle- leveler. This one you need to set from horizontal position into vertical position upwards. After you move the both leveler, you will need to pull the hole cream-white plate toward you. Inside you will see 4 boxes (PCU's) with green levelers. Put inside firmly the cyan box (PCU) under the Cyan box, below the box writes on a sticker Cyan.. After you do this close back the creame-white plate, put the both levelers into horizontal position and close the the front door. If the problem persist than is not just a small fix...That is for now, if the problem continues please ask more guestions. Good Luck. :)
Ricoh Aficio SP... | Answered on Apr 14, 2016
Memory chip at TD sensor: Communication error
Retry of memory chip communication fails three times after the
machine has detected the memory chip communication error.
?? Damaged memory chip data
?? Disconnected inter face
?? No memory chip on the development unit
?? Noise
Replace the PCU.
Ricoh Aficio SP... | Answered on Feb 02, 2016
check thermistor and fuse on ac/dc board
Ricoh Aficio SP... | Answered on Dec 07, 2015
Check drum unit and fuser unit for wear.
Ricoh Aficio SP... | Answered on Nov 23, 2014
Replace the fuser. Then thermopile if it continues.
is a hard drive problem replace hard drive.
Ricoh Aficio SP... | Answered on Sep 16, 2014
Is it a genuine Ricoh Toner or a equivalent refill, if it is the latter then my machine would say empty when actually full. Just keep on using the machine, and have another toner on stand by.
If its a genuine Ricoh toner suggest the machine needs a clean around where the built in (toner) chip is located.
Ricoh Aficio SP... | Answered on Jun 08, 2014
This error is a fuser error .
The fuser is not set properly,remove the fuser and set in properly if the problem persists, fix in a brand new fuser.,
If the error appears again then call an expert to check on it for you.
Good luck
Ricoh Aficio SP... | Answered on May 25, 2014
SC565
*Heat lamp consecutive on error
- Broken main fuser connection
- Check HR thermistors
- Heat roller lamp defective
- Power Supply defective
Ricoh Aficio SP... | Answered on May 10, 2014
problem thermofuse heater stove
Ricoh Aficio SP... | Answered on Apr 12, 2014
Ricoh Aficio SP C820DN Laser Printer Logo
99 questions posted
Top Ricoh Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
sp 5810 reset
  • Office Equipment & Supplies
