20 Most Recent Lexmark X464DE Mono Laser MFP, 38ppm A4 Mono, Print/Scan/Copy/ Fax, Duplex, USB/Ethernet Interface, ... All-In-One Printer Questions & Answers
Of course - why didn't I think of holding down 2 and 6 and turn it off and on - that's perfectly logical! Works great but the user interface certainly isn't very intuitive.
Lexmark X464DE... | Answered on May 13, 2013
Multi-function printers cannot scan and then e-mail the scanned image. They can scan and then fax a document.
You need to scan the document, then save the scanned image, open your e-mail program and create the e-mail then attach the image file (file attachment) to the e-mail before you send the e-mail.
Lexmark X464DE... | Answered on Aug 30, 2011
Try:
To restore factory defaults:
1. POR the machine into Configuration Mode.
2. Use the down navigation button to scroll to the RESTORE
FACTORY DEFAULTS item on the menu.
3. Press Select. The machine performs a POR.
4. The RESTORE FACTORY DEFAULTS sets the MFP non critical
parameters back to the factory settings.
Note: Some settings are not affected: panel language, energy
conserve, paper prompts, registration margins, and page count.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Lexmark X464DE... | Answered on May 20, 2011
1. you may use adobe photoshop to scan images..
2. on the menu, just click import then select the model of your scanner.
it will automatically open the scanning software if not, the default windows imaging software
Lexmark X464DE... | Answered on Jun 13, 2010
Make sure the paper type and size in both trays are the same. If you are using letter size for both trays, make sure the settings in tray 1 and 2 are the same. If the settings are the same and it still fails to grab from the full tray change the engine settings in diag mode. Hope this helps but if you need more assistance, leave a comment and I'll get back to it. Thanks.
Lexmark X464DE... | Answered on May 11, 2010
Hi. You need to do tray linking. When one linked tray is empty, paper feeds from the next linked tray. The size and type settings for all trays must be set from the Paper Menu. To set the paper type or size:
1. On the home screen, touch Menu button
2. Touch Paper Menu
3. Touch Paper Size/Type.
Note: To link the multipurpose feeder, Configure MP must be set to Cassette in order for MP Feeder Size or MP
Feeder Type to appear as a menu item.
4. Touch the right or left arrows to select the same size paper from all paper sources to be linked.
5. Touch the right or left arrows to select the same type paper from all paper sources to be linked.
Note: When the Size and Type settings are the same for any trays, the trays are automatically linked.
6. Touch Submit.
Submitting changes appears.
7. Touch Home to return to the home screen.
Hope this helps.
Lexmark X464DE... | Answered on Mar 19, 2010
Usually you need to access the embedded web server on the printer by typing the IP address of the printer into your web browser address bar. This will open a window that will have all the settings available.
Lexmark X Office... | Answered on Oct 04, 2018
Lexmark X464DE Mono Laser MFP, 38ppm A4 Mono, Print/Scan/Copy/ Fax, Duplex, USB/Ethernet Interface, ... All-In-One Printer Logo
Popular Tags
30 questions posted
Top Lexmark Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
reset pc counter lexmark x464
  • Office Equipment & Supplies
