20 Most Recent BenQ G2220HD Monitor Questions & Answers
High voltage caps on inverters
control the transistors - MOSFET on the powerboard - inverters zone. Good luck!
4/4/2014 11:06:22 AM • BenQ G2220HD... • Answered on Apr 04, 2014
0answers
My BenQ G2220HD Monitor flickers. I've tried my
Try connecting it to a different laptop/desktop, to see if the flickering "follows" the monitor. If not, then the video-card in your computer is the problem -- try connecting another monitor to your computer, to see if the flickering still happens.
11/24/2012 1:15:58 PM • BenQ G2220HD... • Answered on Nov 24, 2012
0answers
Not able to change the
I'm not sure I totally understand the problem, but in general if you can't change to a higher resolution that indicates an issue with your video/graphics drivers rather than your monitor.
I'd try updating your graphics drivers (download the free program Speccy if you need help determining what video card you have) and then seeing if you can set your desired resolution after a reboot.
3/1/2011 9:15:09 AM • BenQ G2220HD... • Answered on Mar 01, 2011
My monitor has a blue tinge and no matter what I
When you get color casting (red, blue, or green), first place to check will be the video cable and all the pins on both ends of the video cable. Try it on another PC as well to make sure it is not the PC problem.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Please leave rating if it helps.
2/26/2011 1:51:57 AM • BenQ G2220HD... • Answered on Feb 26, 2011
Change aspect ratio from 16:9
rt click on your destop...goto settings...change
2/14/2011 10:03:41 PM • BenQ G2220HD... • Answered on Feb 14, 2011
I have a new BenQ G2220HD monitor connected to my
Your onboard video card is going bad on you computer. Some shops may sale an external video device which can be installed in place of your onboard video and it will fix your problem. Average costs aer about $50. Before you try YET ANOTHEr monitor, please try to hook the computer up to a tv to see if the problem pesists, if so, it is time for the above video adapter
1/28/2011 4:18:53 PM • BenQ G2220HD... • Answered on Jan 28, 2011
Repair power button BENQ G2400WD
It is possible to bridge to another power supply. There are simple tutorials on YT to help and the process is not very invasive, if you do not wish to harm the current bezel. I was unable to find a switch online to match the model number. Maybe try something close enough to match.
2/23/2022 2:59:31 PM • BenQ Computers &... • Answered on Feb 23, 2022
Hello I need help with my benq ms 500. Once I plug dstv or laptop on it, it goes off completely within 2 minutes. I tried to clean its fans n board but I stil have same problem
If no issue with other inputs, check the compatibility of the frequencies and refresh speeds.
1/27/2022 10:42:09 AM • BenQ Computers &... • Answered on Jan 27, 2022
Have a benq s6 mid screen doesn’t come on and battery indicator is blinking , so I need a new battery? And is there a reset button on the unit somewhere ?
Go to settings >> system >> About device. Find "Build number" and click 6 times fast on it. Now go to Developer options >> Drawing Section or Rendering Section >> Find "Turn off hardware overlays" or "disable hardware overlays" >> This will force the phone to always use GPU for screen adjustments. no more flickering.
9/21/2021 6:37:51 PM • BenQ Computers &... • Answered on Sep 21, 2021
2answers
Where can I purchase benq q5x3 signal cable
These cables are not different on each brand, they all use the same cable type, so go on eBay and you can find what you need.
9/14/2021 9:26:07 AM • BenQ Computers &... • Answered on Sep 14, 2021
I getting a white screen on my BENQ SD3731 LCD television. Any directions to fix the problem will be helpful
IgmGuru Offer one of the Best AWS Training online. The AWS Certification exam is intended to efficiently deploy AWS resources to design a solution based on customer requirements. The
4/6/2021 4:54:05 AM • BenQ Computers &... • Answered on Apr 06, 2021
Good day. I have a BENQ joybook lite UI02 laptop and would like to do a full factory reset.. i am really struggling could anyone help out please?
Restoring your Joybook to factory default settings: This process will ERASE ALL data on your system drive C: and restore the system to the default factory configuration. If this option is selected, all programs you installed or data you saved on the C: drive will be erased. However, data on the D: drive will not be affected. a. To restore your Joybook to its factory settings, click Full System Restore - Factory default settings under the Restore tab. b. Follow the on-screen instructions to complete the task.
5/5/2020 12:15:40 PM • BenQ Computers &... • Answered on May 05, 2020
BenQ G2220HD Monitor Logo
16 questions posted
Top BenQ Computers & Internet Experts
Marvin
Marvin
Paul Bade
shadow
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • BenQ Computers & Internet
Most Popular Question
benq g2220hd monitor flickers ve tried
  • Computers & Internet
