20 Most Recent
Uniden DECT15602 Cordless Phone Questions & Answers
My 7 month old likes
There are volume knobs on the right or left side of the phone also that may have been missed but at the same time 7 month old child tends to droll which could of gotten into the speaker which means new phone is needed. All I can say is put the phone higher 911 is a number that the child might type in one day.
How to make the phone unsilent
The instructions for changing the ring tone are on page 29 of the manual at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1560-2om.pdf
I just got a uniden
Allow it to charge for at least 2 hours. If after 2 hours you have no dial tone Unplug
your Phone and plug in a regular un-powered phone. If you get DT your phone is out of box defective, and you will need a new one. If it does not have dial tone then there is a problem on your phone line and you
need to contact your phone company. Note, the phone company will charge
you for repairs inside your house.
Followed all directions. Checked out possible
you can try reset your phone, Turn
off the phone, remove the AC adapter, press and hold the page/call
button that is on the phone and plug back your Ac adapter, this will fix
the problem. If that did not fix the problem, let me know.
How do i copy a phone book for the Uniden DECT1560
Kathy,
This should do the trick!
Copying Phonebook Entries to Another Handset:
You can transfer one phonebook entry at a time or all phonebook entries at once.
1) With the phone in standby, press the address book icon.
2) To copy one entry, find the phonebook entry you want to copy, press Menu /Select , and then select Copy.
To copy all entries, press Menu /Select and then select Copy All.
3) Move the cursor to select the handset which you want to transfer the entries to and then press Menu /Select .
If you select Copy All, Are you sure? appears on the display screen. Move the cursor to select Yes, and then
4) The phonebook entries will be transferred to the designated handset. During the copy process, the receiving handset shows Receiving and the ID of the sending handset.
5) When the transfer is completed, Done! appears on the handset.
Notes: • The handsets must be currently connected to the same base.
• If the handset you want to transfer to already has seventy entries in its phonebook, you will hear a beep and Not enough memory in receiving unit appears on the display.
• If the selected handset is out of range or data transfer is cancelled, Unavailable appears in the display, Phonebook listings will not be transferred.
Have Fun!!
I have charged for abt 20 hrs for set up. all I
First make sure the phone jack is working by plugging a working phone into it.
if it is working, use the same phone cable to plug into the base of your new unit.
if you do not get dail tone, place the handset into the main charging base. this should sync the phone up to the base. lift it out and try again.
if you still do not get dail tone or see searching, open the phone and remove the battery. wait 30s or so, plug the battery back in and set the phone in the main charger again. wait 10second and try the phone again.
Can I add another uniden hand set to a uniden D1680 series
The Uniden D-1680 system can have up to 12 handsets registered to the base. (The phone system was sold in bundles with 0 to 11 accessory handsets.) However, this cordless phone system has been discontinued. I can only find used DCX160 handsets (the compatible accessory handset) on Amazon and E-bay.
I hope this helps.
Sync 2 versions of Uniden Dect 6.0 to work off the same base.
Yes, you can join an older and a newer version of Uniden Dect 6.0 cordless phones to work off the same base. Here are the steps to sync them:
- Disconnect the power cord from the base of both phones.
- Take the battery out of each handset.
- Wait for a few minutes.
- Reconnect the power cord to the base of the newer version phone and insert its battery.
- Wait for the phone to register on the base, which should take a few seconds.
- Once the newer phone has registered, repeat steps 4 and 5 with the older version phone.
- The older version phone should now register on the same base.
- Test the phones to make sure they are working properly.
If for some reason the phones do not register on the same base, refer to the instruction manual that came with the newer version phone for further troubleshooting steps.
A uniden phone DECT 6.0. how do i turn on call waiting
Talk to your telephone service provider. There will be a fee.
(Uniden landline phones can make or receive calls; some models have a answering system. Most current models can even check if you have messages on the telephone provider's voice mail. (Sometimes, they'll give spurious voice mail information.) However, they don't have any built-in way of seeing any data (another call) from the telephone provider when the phone is in use.)
