20 Most Recent Yamaha Rx-v465/rxv465 Home Theater Receiver Questions & Answers
3answers
Yamaha AV Receiver RX-V465 picture but no sound.
Check the settings on receiver in the SETUP menu / HDMI / Audio. Here you can choose Amp (sound goes from the speakers connected to receiver), TV (receiver is muted and sound is routed via HDMI to TV) and Amp+TV (sound goes from speakers and also to TV).
Also check in OPTION menu / Signal Info that receiver is receiving sound in recognized format.
1/17/2017 6:55:00 AM • Yamaha... • Answered on Jan 17, 2017
2answers
Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
1/17/2017 6:25:03 AM • Yamaha... • Answered on Jan 17, 2017
2answers
My Yamaha RX-V465 will not stay on. It seems to short out every time and nothing else is hooked up.
If it is not working even without any cables attached, you can check the connectors (especially the speaker ones) for little pieces of cable strands which might short-circuit the connectors. If nothing like that is found, the short-circuit is inside the receiver and you should contact service center for repair.
9/28/2016 7:48:53 PM • Yamaha... • Answered on Sep 28, 2016
When i press power button it just clicks and the does nothing what do i do about repairing
Perhaps you check out master 'power supply' and find bad 'capacitor' (usually). Click sound is because 'stand by power' is fine.
4/22/2016 2:02:08 PM • Yamaha... • Answered on Apr 22, 2016
I have a Yamaha Rx -V465 AV receiver When turn the system on it will not stay on. I switch outlets it would do the same.
First disconnect all speaker cables and all input cables (optical, HDMI, everything expect power). If receiver powers off itself immediately even without anything connected, it is faulty and you need to send it for repair. If it works without cables, then you probably have bad cables and/or short-circuit in the speaker connection and receiver is turning off to prevent damage. Double-check your connection and that no speaker "+" cable has a contact with any "-" cable or connector. Even one little strand of cable touching the opposite polarity connecter is enough to cause a short-circuit.
11/26/2014 1:14:52 PM • Yamaha... • Answered on Nov 26, 2014
0answers
Having trouble syncing audio with my new led tv. I
Normally you would to the TV settings under audio you would have to disable the tv audio and point it to your receiver I assume you have a surround sound. Make sure you are also using the right audio cable RCA or digital optic cable
10/24/2013 6:35:56 PM • Yamaha... • Answered on Oct 24, 2013
IS YAMAHA AMPLI RX SERIES RIPP OFF
Maybe the problem is with your speakers. Shorted speakers or speakers that are being over-driven can cause the receiver to shut down and possibly be damaged.
5/21/2013 8:22:54 PM • Yamaha... • Answered on May 21, 2013
Yamaha rx v465 - Can I have video HDMI output from HDMI input and audio analog input simultaneously?
Not possible with that setup
4/15/2013 1:02:15 PM • Yamaha... • Answered on Apr 15, 2013
0answers
Yamaha Rx-v465/rxv465 Home Theater Receiver Logo
86 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
some television stations not
  • Audio Players & Recorders
