20 Most Recent LG DA-3525 Theater System Questions & Answers
2answers
Can i put an extra sub woofer on my lg da3525 via
How to Connect 2 Subwoofers to One Receiver
Subwoofers produce the deep bass sounds that give home theater the realism of being at the movies. A good subwoofer can rattle the walls during action sequences, while adding depth to recorded music and a heightened sense of feeling in the midst of a televised sporting event. Because most home theater receivers are equipped with a single subwoofer jack, connecting a second subwoofer requires a simple audio adapter available at electronics stores. Self-powered subwoofers have their own built-in amplifiers to drive the bass speakers, so they cannot drain power on the main receiver in a system and thus pose no danger to the equipment, even when an extra subwoofer is connected.
Things You'll Need:
Home theater receiver
Y-adapter with RCA jacks on two ends and an RCA plug on the other, available at electronics stores.
2 RCA subwoofer cables
2 subwoofers
Instructions
Plug the Y-adapter into the home theater receiver's "Subwoofer OUT" jack.
Connect an RCA subwoofer cable to each jack on the Y adapter and route the cables to the subwoofers in the room. Because subwoofers deliver an omnidirectional sound, the boxes can be placed anywhere they won't get in the way, but within reach of an electrical outlet..
Plug an RCA cable into the "Sub IN" jack on the back of each subwoofer.
Connect the subwoofers to wall outlets and turn on each unit by pressing the power button, typically located on the back panel.
Adjust the volume and crossover settings on each subwoofer as desired. The crossover adjustment knob tells the subwppfer which low-end frequencies to reproduce from the audio signal, such as a movie on DVD. All frequencies higher than the crossover setting will be transferred to the other speakers connected to the receiver.
Tips & Warnings
Use subwoofers that are closely matched in power, as rated in watts, when using two subwoofers in a home theater setup.
Disconnect the subwoofers from the power supply while making the audio connections.
Have a nice day...
3/18/2022 6:22:03 AM • LG DA-3525... • Answered on Mar 18, 2022
LG DA-3520 manual
my radio will only play AM WONT PLAY FM I HAVE NOT GOT THE AREAL IT CAME WITH TAKEN ONE OF A DIGITAL RADIO DO YOU THINK I WILL NEED A AM FM AREIAL THANKS
11/5/2015 5:03:00 PM • LG DA-3525... • Answered on Nov 05, 2015
0answers
Da-3525
Be the first to answer 2/20/2013 4:03:19 AM • LG DA-3525... • Posted on Feb 20, 2013Be the first to answer
Keep getting dvd error message when loading disc
Hi, once you are getting a disk read error message with your LG Theater System...
The first thing you need to do is go out and by a cd or dvd lense cleaning kit. You can buy this from most computer stores or electronic hardware stores, make sure you don't buy the cheapest one you see as these tend not to do any good and can cause more harm than good, so go for a mid range to high end one.
Run this disk in your player and this will then clean the lense of any dust or grime that has built up over time this should then solve your problem.
If after doing this you still have the problem then this would indicate that either the laser unit has over heated due tp build up of dust or it has reached the end of its working life and needs replacing.
The problem you have with this is unless its a high end player, then the chances are it would cost less to repair than it would to replace the whole player
12/25/2010 8:34:43 PM • LG DA-3525... • Answered on Dec 25, 2010
Hello. How to set the LG DVD/CD RECEIVER LH-D6230 to the AUX mode if you have lost the remote control. Can it be done manually.
You can't. You need a remote.
Replacement remote control for LG LH-D6230
Remotes World https://remotes-world.com > LG Replacement remote control for LG LH-D6230 with all functions of original one. It replace each button of original remote control. You will receive it with ...
3/13/2024 11:40:59 PM • LG Audio Players... • Answered on Mar 13, 2024
How to remove D Protect from LG CJ45
1/24/2024 12:41:20 PM • LG Audio Players... • Answered on Jan 24, 2024
LG FB162 no sound when connected with Aux
Instead of aux (Blue Connector of PC Sound), try using head phone jack (Green Connector of PC Sound). It if is working fine, uninstall sound driver of your PC, restart PC and install sound driver again. Your problem will be fixed.
12/14/2023 2:41:16 PM • LG Audio Players... • Answered on Dec 14, 2023
How do I reset my LG LHB 625
To reset your LG LHB 625, follow these steps: Turn off the device and unplug it from the power source. Wait for a few minutes and then plug it back in. Press and hold the STOP button on the front panel of the device for at least five seconds. The display will show "INIT" and the device will reset to its factory settings. LG LHB625 Product Support :Manuals, Warranty & More ' LG U.A.E.
11/4/2023 10:38:14 AM • LG Audio Players... • Answered on Nov 04, 2023
Audio not working on VCR side of LG LRY-517 DVD/VCR combo player
The back of the lry517 has 2 sets of audio outs and 1 set of audio ins. If you are using the component video outs, use the audio outs to the right of the component outs. If you are using AV1, it should be the audio to the left of the component outs. The tape's audio may be very low, try turning up the tv volume? You could also try adjusting the tracking? Have you tried using the AV1 outputs? It would be Composite Video and stereo audio.
4/25/2023 4:29:49 AM • LG Audio Players... • Answered on Apr 25, 2023
2answers
Remote control code for LG
2/14/2023 5:45:07 AM • LG Audio Players... • Answered on Feb 14, 2023
I have a “please wait” problem in my lg home theatre (model hb906sb) ??
The "please wait" problem in your LG home theatre (model HB906SB) is likely an issue with the system's firmware or software. Try unplugging the system from the power source for a few minutes, then plugging it back in and turning it on. If the issue persists, try performing a factory reset of the system. If none of these solutions work, contact LG customer support for further assistance.
2/14/2023 5:36:07 AM • LG Audio Players... • Answered on Feb 14, 2023
2answers
How can I unlock a LG HT LHD625 to play DTS? The HT's Display recognize DTS but that is no sound.
It is not possible to unlock a LG HT LHD625 to play DTS if it does not support DTS decoding. The display may recognize the DTS signal, but if the HT does not have the necessary hardware and software to decode the DTS signal, it will not be able to produce any sound. You may need to use a different audio format or upgrade your HT to a model that supports DTS decoding.
2/14/2023 5:34:50 AM • LG Audio Players... • Answered on Feb 14, 2023
LG DVD Receiver HT552TH is not switching from DVD to AUX or Band. What to do?
Here are some steps you can try to troubleshoot the issue with your LG DVD Receiver HT552TH:
  1. Make sure that the AUX or Band input is properly connected to the receiver.
  2. Try resetting the receiver to its default settings by unplugging it from the power source, waiting for a few minutes, and then plugging it back in.
  3. Check the input settings on the receiver and make sure that the correct input is selected for the AUX or Band.
  4. Try using a different remote to see if the issue is with the remote or the receiver.
  5. If the issue persists, it may be a hardware problem with the receiver, and you may need to contact LG customer support or take it to a professional repair service.
2/14/2023 5:23:08 AM • LG Audio Players... • Answered on Feb 14, 2023
I have a LG Tribute HD. There is no option for central standard time zone anywhere. Both the network automatic time and the manual time zone s ard wrong.. I live in Topeka Ks which Time zone do I use...
Topeka, Kansas is in the Central Time Zone (CT). Therefore, you should select the "Central Time" or "CT" time zone option in your phone's settings to ensure that the time displayed on your phone is accurate for your location. If you are unable to find this option on your LG Tribute HD, you may want to try updating your phone's software or contacting LG customer support for assistance.
2/14/2023 5:19:10 AM • LG Audio Players... • Answered on Feb 14, 2023
Wat is s- protection on my lg home theater systerm
I'm not sure what specific LG home theater system you are referring to, but "S-Protect" is a feature found on some LG home theater systems that is designed to protect the system from damage due to power fluctuations or speaker wire issues. When the system detects a potential problem, it will automatically shut down to prevent further damage.
2/14/2023 5:14:06 AM • LG Audio Players... • Answered on Feb 14, 2023
My LG home theater doesn't want to turn on,tried it manually and with remote but still,what could be the problem
Could either be an issue with the power supply or there's a short in the main power amp section. You should check all speaker connections and cables and the speakers themselves. Any wiring touching each other or a faulty speaker can cause an overload thus activating the safety features in the unit.
12/29/2022 5:38:03 PM • LG Audio Players... • Answered on Dec 29, 2022
I have a LG 780 head and the sound went out in the speakers is the someone who can fix them
The wires and the audio amplifier are not working for your speakers and it would be more cheaper and easier to buy new speakers then to try and repair the speakers that are broken.
12/24/2022 7:35:56 AM • LG Audio Players... • Answered on Dec 24, 2022
2answers
LG ' LH-T550TB
Your question ............................. is ..................................
12/7/2022 6:50:52 AM • LG Audio Players... • Answered on Dec 07, 2022
LG DA-3525 Theater System Logo
Popular Tags
8 questions posted
Top LG Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • LG Audio Players & Recorders
Most Popular Question
put extra sub woofer lg da3525 via
  • Audio Players & Recorders
