20 Most Recent Insignia NS-H3005 Theater System Questions & Answers
How to reset DVD VCR?
put into dvd mode with no disc in tray turn on and hold stop button 5 seconds this will reset to factory video/audio mode
3/12/2013 8:13:03 PM • Insignia... • Answered on Mar 12, 2013
The progressive scan mode is on and i cant get it
Look for a button on remote to change resolution settings. If you have no pict. hook up the green output to your yellow input will give you a picture to see the menu.
4/9/2011 12:07:24 AM • Insignia... • Answered on Apr 09, 2011
I want to know what
Hi, Please get the code here : www.dvdoverseas.com/dvd.htm
www.regionfreedvd.net/
Regards,Jay__pmnb
2/25/2011 2:59:29 PM • Insignia... • Answered on Feb 25, 2011
My insignia model number NS-H3005 is stuck in
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealersip.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
8/13/2010 12:57:34 AM • Insignia... • Answered on Aug 13, 2010
2answers
Why can't I program my insignia remote to a davinci d7 home theater system
Hey there! So, programming a remote can sometimes be a bit tricky, especially when it comes to compatibility between different devices. In this case, it seems like you're having trouble programming your Insignia remote to work with your DaVinci D7 home theater system. The thing is, remote controls are designed to work specifically with certain brands and models of devices. While Insignia remotes are usually quite versatile, they may not be compatible with all home theater systems out there, including the DaVinci D7. Different home theater systems often use different communication protocols or codes to receive commands from the remote control. If the codes used by your DaVinci D7 are not included in the Insignia remote's pre-programmed list, it won't be able to communicate effectively with your system. However, don't worry just yet! There might still be a few options to explore. First, make sure you're following the correct programming instructions provided by Insignia for your specific remote model. Sometimes, a small oversight in the programming process can cause issues. If you've followed the instructions correctly and it's still not working, you could try reaching out to Insignia's customer support. They might have additional information or alternative methods to program the remote specifically for the DaVinci D7 system. In some cases, a universal remote might be a good alternative. These remotes are designed to work with a wide range of devices and often offer more customization options, allowing you to program them for devices that aren't on the pre-programmed list. So, while it might be a bit disappointing that your Insignia remote isn't working with the DaVinci D7, there are still a couple of avenues to explore. Give those suggestions a shot, and hopefully, you'll find a solution that gets your remote and home theater system working together seamlessly. Good luck!
8/14/2023 11:26:54 PM • Insignia Audio... • Answered on Aug 14, 2023
Hi my names ed and i bought this to connect an meow headphone to insignia tv but can not get it to pair
1 With your stereo headphones turned off, press and hold for four seconds. The blue and red LEDs blink alternately. 2 On your phone or MP3 player, selectINSIGNIA NS-CAHBTOE01 from the list of discovered devices, then enter the password 0000 (four zeros) (if required) to pair your headphones
2/22/2019 5:40:57 PM • Insignia Audio... • Answered on Feb 22, 2019
I have an insignia portable speaker with voice assistant and need the user guide
If you visit the makers website they should have free PDF of it.
8/12/2018 5:07:06 PM • Insignia Audio... • Answered on Aug 12, 2018
I have two Insignia headphones that I have taken with me on vacation. One at a time works fine but I’ve forgotten how to set them up in tandem. Can u help
Have you tried the makers website? Sometimes they have a free PDF of the manual.
2/4/2018 6:50:36 PM • Insignia Audio... • Answered on Feb 04, 2018
How top connect a rca turntable to an insignia receiver (speakers 2)
If the receiver does not have a dedicated socket for playing back records, you will probably need a magnetic cartridge pre-amp. You can then connect via any left and right audio imput. If you do it without a pre-amp the sound will be there, but too low to listen too.
1/29/2018 4:46:45 PM • Insignia Audio... • Answered on Jan 29, 2018
Insignia NS-H3005 Theater System Logo
6 questions posted
Top Insignia Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Audio Players & Recorders
Most Popular Question
progressive scan mode get
  • Audio Players & Recorders
