20 Most Recent
Kenmore 24 in. 17262 Built-in Dishwasher Questions & Answers
My dishwasher soap dispenser is not dispensing
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
oyp8709
Kenmore 24 in....
Answered
on Sep 29, 2010
Kenmore Elite 17262
I just took my Kenmore elite 17262 apart because it was not getting the
top rack clean and the soap was not being used up- i.e. low water
pressure. The short story - Misc. objects were clogging the
screen/grinder, I cleaned out olive pits, a small plastic bag, pieces
of plastic and masking tape (from labeled Tupperware) and stringy food,
now it cleans much better. Getting to the grinder compartment was
tough. A few tips: the top rack drawer slides come out after you remove
the stops in front by pushing the buttons and pulling the stops toward
the center of the machine. The tube at the back unclips from the
ceiling and the back wall and tilts down as you slide the connection
out from the supply tube at the bottom. Hold the spray arm and turn the
plastic centerpiece clockwise to screw it down through the arm. Rotate
the top manifold/supply pipe clockwise 1/8th turn to release; next you
will need a small torx (star) driver to take out four screws holding in
the screen/manifold. Note where the two nylon washers go on the
pivot/axle for the arm. Under the screen/manifold is the grinder cover,
remove one smaller torx screw and it will snap out (may be stuck in
with accumulated goo). I used a shop vac to clean this area but sponges
and tweezers would do, check for damage to the screen and blade.
Inspect wash out and reassemble everything in order. The fine mesh
screen pops off with a large screwdriver (careful cleaning the screen)
Replace the two nylon washers under the pivot/axle and install the
supply pipe manifold just before inserting the center pivot, if you put
the pivot in first the manifold will not seat. A work light and small
parts dish help. Use appropriate force on plastic parts and common
sense. If you have hard water try the vinegar trick also (another post)
or first. - good luck
Kenmore 24 in....
Answered
on Feb 12, 2009
Door won't close
I have the same dishwasher and the latch has never worked. Finally after 9 months and many service trips I went back to the store and they gave me a new dishwasher. Dealing with Sears has been a nightmare.
Kenmore 24 in....
Answered
on Mar 30, 2008
Kenmore dishwasher won't run
Common solutions for: Kenmore Dishwasher will not start. The door switch prevents the dishwasher from running and working while the door is open. If the door switch is defective, the switch will stop the dishwasher from running even when the door is closed. If the thermal fuse has blown , it will prevent the dishwasher from starting.
Make sure your dishwasher is fully and also securely plugged in and that the circuit breaker switches haven't been tripped. .It also houses the door latch switch that provides the power to the dishwasher controls. If the dishwasher door isn't closed properly, the dishwasher won't receive power to finish a wash cycle You could call a repair person that fixes dishwashers to have a look at it and see what the problem is with the dishwasher
Kenmore...
Answered
on Sep 05, 2020
