20 Most Recent
Sony Bravia DAV-HDX265 Theater System Questions & Answers
Child Lock Sony DAV-HDX265
- Press "System Menu"
- Press the Up arrow ^ or dowm arrow v repeatedly until "CHILD LOCK" appears.
- Press ^ or v to select a setting for "OFF" or "ON."
- Now press the "+" button and the setting is changed to your selection.
- Press "SYSTEM MENU" again to exit.
- To remove a disk while child lock is on
- Press the "eject button" on the remote and press "DISK SKIP" repeatedly until the desired DISK indicator [1-5] lights up.
- If you have any comments please feel free to leave them here.
- Hope this helps and thank you for using FixYa.
Regards,Tony
Some how i accidentally child locked my Sony
- Press the Up arreo ^ or dowm arrow v repeatedly until "CHILD LOCK" appears.
Regards,Tony
What is the problem when
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
I have a bravia home
The 4 Codes I have for sony DVDs are 2241, 2767, 2137 & 2239 if your remote needs more than 4 Digits then just add 0s before.
Hi - I have a
Plug audio RCA cable in Audio Input of DAV-HDX265 and cable box Audio Output. Set DAV-HDX265 to TV/Video Input to get cable sound in speakers.
Let me know if you have additional question.
Thanks.
"No Disk" message
Your dvd lense need cleaning .
For that buy lense cleaner disk from nearest computer shop then put that disk into cd/dvd rom then play it then it clean dust from lense then you can use it again .
But if still same issue then you need to replace your dvd lense .
Let me know if you need further assistance.
Thanks for using FixYa.
Connecting SONY TA-D505 amplifier LBT-D505
Hi David, do you want to connect the ST-D505 tuner to the TA-D505 amplifier?
You just have to connect an audio cable of two RCA (red and white) from the audio output L and R of the tuner ST-D505 to the input of Tuner in the amplifier TA-D505
Remember to connect the FM antennas and the AM Antenna Loop on the ST-D505 tuner
To listen to it, you have to select Tuner on the TA-D505 and enjoy the favorite radio stations
I hope you have my comments
Greetings Franco Dosil
Hola David, quieres conectar el sintonizador ST-D505 al amplificador TA-D505?
Simplemente tienes que conectar un cable de audio de dos RCA(rojo y blanco) desde la salida de audio L y R del sintonizador ST-D505 a la entrada de Tuner en el amplificador TA-D505
Recuerda conectar las antenas de FM y la Loop Antena de AM en el sintonizador ST-D505
Para poder escucharlo, tienes que seleccionar Tuner en el TA-D505 y disfrutaras de las estaciones de radio preferidas
Espero que te sirvan mis comentarios
Saludos Franco Dosil
https://elektrotanya.com/sony_lbt-d505_d505cd_d505cdm_d505m.pdf/download.html
