20 Most Recent Hifonics OLYMPUS OLM1612 Car Subwoofer Questions & Answers
yea for sure thats a good upgrade. You shouldnt havebeen able to blow the kenwoods with 400 watts though-meaning that they probably blew from distortion which causes heat(fast) Check your gain on the amp start it out at 1/4 gain and turn up your deck to the point where you can hear distortion from your mids and highs or to the maximum level that you listen to your music at. If you're jamming out at a level that is causing distortion then you will be sending a distorted signal to the amp as well. The amp then amplifies the distorted signal through the subs which overheat and blow. So find the distortion spot and then turn it down just a little bit till it clears up your sound-then adjust your gain on the amp up slowly until you cant hear it getting any louder. Once you have done that you have reached the limit of CLEAN power that you are going to get.Thats where you want to keep it. Watch the bass boost too if you have the bass up on the deck and then crank up the bass boost on the amp it really f's up the signal too. Good luck
Hifonics OLYMPUS... | Answered on Jan 31, 2010
Your amp could still have a short not allowing it to provide audio to your speakers. Confirm that your speakers are not blown. Use VOM meter to confirm the ohm rating.
Hifonics Car... | Answered on Feb 04, 2019
This means that the remote wire is 0V instead of 12V. Try to connect it over from the 12V to check if it powers on.
Hifonics Car... | Answered on Jan 15, 2019
MKe sure you have 12 vole coming from m your remote will re after your system starts up.
Hifonics Car... | Answered on Dec 03, 2017
Run a dual 2ohm sub on it. Bridged parallel. That will give you your max. 600rms/1200max
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Hifonics Car... | Answered on Oct 04, 2017
There is nada wrong with your preamp and changing it will accomplish nothing. If your channels are allegedly clipping it is due to the fact that it is being over driven. A bad preamp could not over drive your amp!
Have to be careful with tone controls at high levels. Every 3db increase compels amp to double power at that frequency. So if you are blasting at 2000 watts and you boost a control by that amount, your amp will put out 4000 watts and clip. If plus 6db then it is 8000 watts!
Hifonics Car... | Answered on Jun 20, 2017
Some amps will not power up internally if u donot have remote wire. Also if u connect power then remote wire it will not power up until u reconnect in correct order. But if all that is ok. Than u have a bad amp
Hifonics Car... | Answered on Mar 11, 2017
Hifonics OLYMPUS OLM1612 Car Subwoofer Logo
1 questions posted
Top Hifonics Car Audio & Video Experts
Marvin
Marvin
Tom Chichester
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hifonics Car Audio & Video
Most Popular Question
2 kenwood 3011 400 watts rms 12oowatts
  • Car Audio & Video
