20 Most Recent
Soundstorm Laboratories SD870TS Car Video Player Questions & Answers
What is the parking brake
very simple ground the e brake wire that is all you also may need to run a switch in between where you can reach it cause somtimes decks need to be ungrounded(e brake wire) then re grounded when you turn it off then back on but yours shoud just be able to ground to the back of the stereo with the aftermarket deck ground(black)
plz let e now ifyou need further help
Kieran
Modelo sd745t radio para coche tengo problemas que el panel fron
Es posible que alguno de los switches este defectuoso y se a de haber quedado oprimido y eso causa que se bloquen todos las funciones.Por lo regular,cuando un switch esta defectoso no se siente el click al oprimirlo.
Espero que esta informacion te ayude en algo.
Gracias y suerte
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
