20 Most Recent
Power Acoustik PTID-5850NR Car Video Player Questions & Answers
NEED A PRICE
I'm interested in the wiring harness that you have .. If you want, I can give you good price for it.
call or text : 8324206785
Hi,I a model PTID-5850NR..... The
Hi , I have the same model .
I want to buy from you the wiring harness that comes with this model
If you accept please call or text me : 8324206785
My power acoustik cant remem
Make sure the yellow wire is going to a source that is still hot when the key is turned off. The yellow wire controls the memory and must have voltage going to it all of the time.
PTID-5850NR screen does not work
Hello :
Try to reset it and problem will be solved . If not then the best advice is to take it back if you still have the guarantee . or take it to the service .
good luck .
rate if useful please !
Power Acoustik PD-624B 6.2-Inch Double-Din in-Dash LCD Touchscreen DVD Receiver with Bluetooth. The Radio cannot play any video, gives warning message.
Question edited for a lot more clarity, full make model (what it is)'.
Question moved from Televisions category.
The warning message may have been useful!
People don't realise that factory car audio is operated by and monitored by the Body Control Module (BCM) on a computer network. Your warning chimes and indicator clickers are generated by the BCM and played through the car audio system. The computer has no idea that this new device is!
Take it to an auto electrician or to an Alarm / Audio installer and see if their professional bi-directional grade scan tool computer can reprogram the BCM to ignore your device. Or just put the old one back.
I have a power Acoustik cpaa7dd double den car radio and I keep getting unknown disc errors
- Make sure the disc you are trying to play is compatible with the radio. The radio may not support certain formats or types of discs.
- Check the disc for any visible damage, such as scratches or fingerprints, that may be preventing it from playing properly.
- Check the CD player for any debris or foreign objects that may be preventing the disc from being read properly.
- If you are using an aftermarket CD changer, make sure it is properly connected to the radio and functioning correctly.
My power acoustik pd-620hb won't turn off
POWER/MUTE Button Press it to turn on the unit.Press and hold for 2 seconds to turn the unit off . Press the button briefly to Mute . Please note that the volume will be muted on all audio output connector.
